PT Cruiser Forum Car Videos
Custom Wheels
Ignition Key
Old 05 Mar 2008, 11:12 pm
uskeith uskeith is offline
Default Ignition Key
01 Year 74,000 miles -- all of sudden my key will turn the ignition switch, what's up with that?
Old 06 Mar 2008, 08:18 am
CREWZIN CREWZIN is offline
Default Re: Ignition Key
to the forum.
Sounds like the tumbler has come loose from the steering wheel housing. Never heard of your problem before. You might stop at a locksmith and have him/her take a look at it. Hopefully you won't have to replace it.
2000 PT. 96K miles, Original Owner
Old 06 Mar 2008, 04:57 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Red face Re: Ignition Key
Boy! I got a new one for ya!
I've presently got two 2006, low-mileage Cruisers. Get in the soonercruiser yesterday, put the key in, no problem.....but, won't turn at all. Jiggle the switch a little, try again....no luck! Wiggle the steering wheel and try again....no luck?
What's the problem here???
ME!
Use the right Cruiser key, dummy!
(Vert key doesn't fit soonercruiser!)
Old 06 Mar 2008, 05:50 pm
Originally Posted by soonercruiser View Post
ME!
I'm always grabbing the wife's KIA keys instead of the Cruiser or vise versa and wondering why the fob won't unlock the darn car.
But I think uskeith has an entirely different problem.
Old 09 Mar 2008, 08:24 am
Smile Re: Ignition Key
Thanks guys, it turns out to be a tumbler problem as Crewzin has suggested.
I have it going again. I almost bought another key but at $85.00 with programming I figured I would try something else first. I only have 1 PT and one key although it sure felt as if I had the wrong key.
Thanks again,
Old 15 May 2008, 10:38 pm
Mal Mal is offline
Default Ignition key will not turn
The key wont turn has happened to my cruiser twice. This wasn't the normal steering wheel lock thing. In both cases (about 3 years apart), I was ultimately able to free the lock. In the second case, I am quite sure what fixed it; in the first I am not sure but think it was the same. I tried all the normal tricks, pushing key, turning wheel, banging the top of the wheel, jiggling the key, jiggling the trannie shift lever, holding pressure up/down/angles/part out...ad-nausium.
In both cases it happened that my wife parked the car on a street with considerable crown and when I got to the car, the steering wheel was not locked. In both cases, I think the fix was to turn the wheel until it locked. I then turned the wheel to both points where the lock prevented it's turning. I noticed a slight click near one side (it happened to be the right) that repeated each time I passed it. If I turned the wheel to one extreme (the right in my case) and reversed it to just slightly passed the click; the key turned. In all other positions, it would not.
It took no additional pressure but was more like opening a safe....the steering wheel just had to be moved just so.
I hope this might help someone in the future.
Old 16 May 2008, 10:14 pm
The real problem was in the tumblers. I found that the last tumbler in the row was causing the problem. I removed it, put everything back together and have not had any problems since.
Old 17 May 2008, 05:45 am
Mal Mal is offline
I am quite sure these are two separate problems with the same symptoms.
vB code is On
Ignition Hot Fuse Under Hood? brymck Sound and Security Forum 3 03 Jan 2008 09:14 pm
Help. No Power Door Locks with Ignition off. Lloyd General PT Cruiser Discussions 2 15 Jul 2007 10:17 am
Battery good not sure if is starter or ignition Rob in tx Tech & Performance Forum 3 03 Jul 2007 11:34 pm
MSD Ignition Coil imduke2u Classifieds: For Sale/Trade 0 27 Sep 2005 11:44 am
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
  Free Advertising | Loan | Yahoo Personals | Shares | Mobile Phones
