PT Cruiser Forum Car Videos
Custom Wheels
possible EGR valve problem
Old 10 Mar 2008, 06:17 pm
pendart44 pendart44 is offline
Angry possible EGR valve problem
Recently we had the timing belt and water pump replaced on our 02 Cruiser. Shortly afterwards whenever it was put in park or idling it would begin to shake and shimmy. My wife took it back to the mechanic mad as you know what!!! He hooked it up to the scanner and a code for the EGR came up. We spent way more than I wanted to for the timing belt/water pump replacement. I checked the Haynes manual to see if I could replace it myself if possible. Forget this! Would a bad EGR cause this shaking or maybe the PCV valve? How about the plugs? Thanks
Old 10 Mar 2008, 08:12 pm
Cokebear1 Cokebear1 is offline
Default Re: possible EGR valve problem
We had to replace the EGR valve on ours. When ours went, it ran very rough whenever you took your foot off of the gas to slow down. It ran fine when we were driving at highway speed. Dave had to two-foot it all the way from Indiana to Ontario! We had taken it to a dealership in Indiana and he tried to tell us that the cam had shifted! There's a thread on PTCrew right now about replacing EGR valves, and it includes pics.
Old 11 Mar 2008, 12:11 am
ucantcme's Avatar
ucantcme ucantcme is offline
Send a message via AIM to ucantcme
EGR flow 400
Seems to be the same problem.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Altezza Tail lights, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Shift Plate, Chrome Antenna Bezel, Chrome Grille inserts, Turbo Catback exhaust, Scan Gauge II,
back-up camera, and a system containing 3 MTX 10" subwoofers and an eclipse 1000watt amplifier.
Check me out on Car Domain!
Old 11 Mar 2008, 11:58 am
2k1PT 2k1PT is offline
As far as I can tell, there is a blockage in the egr valve, should not have anything to do with a timing belt.
Changing the PCV will probably help, but if you are geting the same error as I am, P0400, or P0401, its most likely not the root cause. My PCV was pretty bad though, almost no rattle when I shook it, and after replacing the spark plugs and the PCV the car is runing much better, but the light is still on...
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
  Advertising | McDonalds | Credit | McDonalds | Personal Loans
