Engine Light on P0139 code
Old 24 Mar 2008, 11:14 am
Default Engine Light on P0139 code
I understand this code is a sensor relating to the catalytic converter. How easy or hard is this to change out? Any special tools needed and how much does the part cost? My local dealership said it can cost anywhere from 80 to over 175 depending on the sensor, and autozone said it costs about 25 each. Big difference in price, so any info would be helpful.
Old 24 Mar 2008, 06:02 pm
Default Re: Engine Light on P0139 code
Your code if for the downstream oxygen sensor which is located on the left side of the catalytic converter. Trace the electrical lead from the sensor to the electrical connector and disconnect it. Unscrew the sensor with a suitable wrench (it's not necessary to use a special 02 sensor socket.
Forget the dealer and either do it yourself or ask around for a trusted mechanic.
Old 27 Mar 2008, 10:55 am
how about that. I took my gas cap off and retightened it and the error code went away. Saved me a bunch of money. Thanks.
Old 22 Feb 2010, 09:23 pm
Thanks every one for your anwsers. The right code was P0139 and I am headed to autozone now.
Old 25 Sep 2011, 05:30 pm
Please excuse bringing up an old thread. Since this code has been addressed
before, I didn't see the need to start a new one. My 05 Touring has thrown
this code. I was going to replace the O2 sensor, but Autozone gave me a
list of possible causes which include other possibilities as well. Should I start
with replacing the sensor? I'd like to avoid going to a mechanic if it's a simple
fix.
Old 25 Sep 2011, 05:38 pm
First, I wouldn't put a whole lot of trust in your AutoZone parts counter guy. Second, shutterbug seems to think that re-tightening the gas cap took are of his code so you might as well try that. Make sure it clicks 3 times when tightening it. Then it might take a day to go away as the computer has to recognize that everything is OK before turning the engine light off. if it doesn't go away, yea, I'd start with the downsteam 02 sensor next to the CAT.
Old 25 Sep 2011, 05:49 pm
THATS why this forum is a great resource. Thanks Crewzin. I did check the
cap, but haven't driven it much since. As an FYI, here's the list that was in
Autozone's system.
1 Oxygen sensor defective
2 Fuel system running very rich or lean
3 Engine misfire condition (I've not noticed anything)
4 Fuel pressure very high or low - fuel pump or pressure regulator
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 15 23 Jul 2010 06:09 am
Check Engine light code help sohc1996 Tech & Performance Forum 6 15 Jul 2009 07:14 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Clearing check engine light Blade Tech & Performance Forum 10 27 Mar 2004 01:48 am
