PT Cruiser Forum Car Videos
Custom Wheels
Intake Selection
Old 28 Mar 2008, 11:29 am
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Default Intake Selection
Hey, I have a non turbo 2001 PT Cruiser. I am purchasing a cold air intake and I was looking for input from anyone with experience from different brands. Currently, it looks as though i might be getting an Airaid intake. Opinions please?
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Pictures of my PT
http://www.banfielddesign.com
Old 28 Mar 2008, 12:46 pm
ucantcme's Avatar
ucantcme ucantcme is offline
Send a message via AIM to ucantcme
Default Re: Intake Selection
K&N is awesome. Haven't heard but good things from them on the Cold Air intake. I bought the drop-in filter from K&N, nothing bad what so ever.
AirAid and K&N are good companies.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Altezza Tail lights, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Shift Plate, Chrome Antenna Bezel, Chrome Grille inserts, Turbo Catback exhaust,
back-up camera, and a system containing 3 MTX 10" subwoofers and an eclipse 1000watt amplifier.
Wish List: Aftermarket tires/wheels, turbo!
CUSTOM DECALS FOR YOUR CRUISER!
Old 28 Mar 2008, 09:32 pm
PTmodrod's Avatar
I forgot to mention this earlier but the only reason I am looking at getting the Airaid intake is due to the price difference. The Airaid seems like a much better deal and from what I have read, doesn't seem to be too much different from the K&N intake in gains.
Pictures of my PT
Old 28 Mar 2008, 10:27 pm
Mean Green Mean Green is offline
The best I've seen on the dyno is 2-5 hp gains and that isn't even noticeable. The sound is nice, though. The Airade is a better setup because it closes off hot engine air from the intake.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 28 Mar 2008, 10:34 pm
lakersfan1 lakersfan1 is offline
I just bought the Airaid for the 06+ and installed yesterday. Gets louder than I though at full throttle, but I can tell a difference in power above 3000 RPM. Took me 10 minutes to install. Only thing I didn't like is the throttle body adapter. Looks like it's disrupting air bigtime. I'll probably take it off and try rounding off the edge with a Dremel to make a smoother transition.
Somehow the 06+ is supposed to make more HP and less TQ than the kit for the 05- even though I thought the engines were pretty much the same.
Old 29 Mar 2008, 12:38 am
cleverklutz cleverklutz is offline
The airraid sounds good, but I'm not too thrilled by the fit and finish. It leaves big gaps where it seals with the airbox. I can post pics if you'd like. I think it can still suck hot air, but then again so could the stock intake. I'm thinking I'll try going back with the stock airbox and modding it quite a bit. I want to do a ram air setup with a cheap hoodscoop, which will be a true cold air intake. If I utilize the stock air inlet on the airbox and rotate it 180* then I shouldn't have to worry about moisture from rain and such as the air will enter under the filter and go up. I have to check if I can remove that nose that goes over the battery, I want the intake to sound as good as the airraid.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
Old 29 Mar 2008, 08:32 am
PTmodrod's Avatar
I know that most people claimed to gain around 5 HP and I understand that that really is not too noticeable, but the sound difference will be nice, and I will be glad to have a reason to open my hood at car shows. I'll look into modifying the airbox to cut off a bit more engine heat too. Thanks to those who have already posted and I'm still interested to hear more. As a plus, that will finally put me over the edge and help me edge out my friend and his Cobalt SS. Usually I am neck and neck with him the whole way!
Pictures of my PT
Old 29 Mar 2008, 12:52 pm
Placebo effect. Makes more noise at 3k. I used to think my '01 was quicker with the Airade, too. When I switched back from the Airade to stock I discovered that the '01 "sounded quicker" and there was no difference.
Old 29 Mar 2008, 12:59 pm
Not sure. It seems to pull up the hill I live off alot faster. Too bad the NA PT Cruiser crowd doesn't seem to be into dynoing thier mods. I can't see how replacing that tiny little accordian pipe alone doesn't help power. But, then the PT only winds out to 5500RPM or so until power rolls off. I'm coming off a car that wound to 8,000 RPM, so it made a more profound effect .... and it was dyno tested several times. Perhaps if I get a few more actual engine mods going, I'll do a quick A/B on an engine dyno to test the two intakes independantly side-by-side.
Old 30 Mar 2008, 01:33 am
What I do to see if I've noticed a gain is do several 0-60 runs with a stopwatch. Not rocket science, but if there is a gain, you should notice it. I ran 12.5 seconds 0-60 when I got it. New plugs, wires, coil, CAI, and exhaust. It's now up to 12.5 seconds... When I did similar mods to my Dodge Dynasty I went from 10.5 seconds to 9.5. Not sure why my PT is so bloody slow!
Ben
vB code is On
3.0-inch AGP Intake strangelove Turbo Performance 7 21 Oct 2006 03:52 pm
GT cruiser powder coated intake tthrift Classifieds: For Sale/Trade 1 04 Jul 2004 12:29 pm
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
pt tuning intake VS Ebay intake gt_tuner Turbo Performance 8 21 Jun 2003 11:41 pm
AIR INTAKE FROM AMX1397 amx1397 Turbo Performance 6 03 Jun 2003 10:22 pm
  Credit Cards | File Host | Landscape Photos | Car Insurance | Remortgaging
