New guy here and I tried the search to find an answer but have failed. My question, I have a 2004 PT with the CEL on. When the key is turned to the on position, it beeps, 5 pause then 1, I assume code 51. I have tried the on/off method with no results. Is the beeping in fact the code? And woud the translate to a P0051 code if so? I plan on hitting up an Autozone later, but I figured I would try here as well.
Thank you, The new guy - Dave |
the beeps dont mean a code at least i dont think so, do as hooligan said look were your mileage is thats were a code would show up
Yes, my 01 gives me 5 chimes , then 1 chime if i just sit in the car and turn the key to the ON position without starting it. It doesn't mean a thing as far as I know.
It also chimes if I turn the lights on without the key in the ignition and flashes "head lights" in the center dial. The CEL (Check Engine Light) with the little picture of the engine, stays on until the engine is running.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 95K miles, Original Owner Visit My Home Page www.CREWZIN.com Last edited by CREWZIN : 28 Mar 2008 at 07:59 pm. |
Thanks for the help. Sorry I should have stated the CEL Check Engine Light was lite even after the engine was running. That is why I assumed a code was thrown.
I did try the on/off three times trick with out any luck. I had the codes read, and P0700 was pulled. Took it to a Transmission shop and was on my way in 25mins after the fix. Thanks again. Great site, and I hope to become productive member. Dave |
Dave,
There's quite a few owners that have had the P0700 code and it turned out to be a couple different things. Can you tell us what's on your paperwork that describes what they did at the shop or did they tell you exactly what they did?
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 95K miles, Original Owner Visit My Home Page www.CREWZIN.com |
Sorry I did not respond sooner. I have no paperwork. I sent the wife over to the shop to have the work done. From what she said, they added a bit of trans fluid and replaced a sensor(?). They must have found her attractive or something, as they did what they did and sent her on her way after saying have a nice weekend. That's right, she had the PT fixed at no cost. I need to look around this thing and identify what was replaced.
OK, forget that, just send pictures of the wife!
HaHa, I'll see what I can do!
Hope they put in ATF+4, the tranny is very fussy.
How many miles on the PT? You should have the tranny flushed at about 50,000 miles.... (and Crewzin beat me to the pic request... )
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
