P0700 Transmission Control System Malfunction
Old 29 Mar 2008, 12:56 pm
Default P0700 Transmission Control System Malfunction
Is this something i can replace or fix myself? Just what the heck is this? Could really use some help on this. My cruiser is my only transportation.
If any one here can help--------Thank you in advance.
Old 29 Mar 2008, 10:06 pm
Default Re: P0700 Transmission Control System Malfunction
P0700 is a pcm trouble code that basicly says there is more trouble codes in the trans controler side of the pcm.
in order to find out what those codes are you will need a scan tool and then once you have the codes further diagnois can be done.
depending on what codes come out of the trans controler it could mean something simple like a bad speed sensor or some kinda bad like a loss of prime. gear ratio error codes can be caused by faulty sensors.
Best advice take it to either a dealer you trust or a tranny shop you can trust. if your not comfortable driving it get it towed.
whats the oil condition? does it smell burnt and is it dark in color? and is the level correct
Old 30 Mar 2008, 09:46 am
My GT just had that PO700 code and is now being rebuilt by the dealer. Mine locked in 2nd gear, then when I slowed down the engine died. Every time I got it started and put it in gear the engine died. If you are just showing the code, but nothing drastic happened it may not be serious.
Old 31 Mar 2008, 02:30 pm
The number 1 warranty issue on the 41TE are solenoids.
Old 15 Apr 2010, 11:35 pm
Cool Re: P0700 Transmission Control System Malfunction
trans wont shift out of 1st gear. Had codes p1490,p1495,p0700 . I had disconnected the battery about 10 times, then drove the car and would not shift out of 1st gear, then the above codes displayed.
Old 16 Apr 2010, 06:29 am
...and your question is? If you read the posts above yours, there's not much you can do so get to a dealer or transmission shop to see what the problem is.
Old 07 Dec 2011, 07:37 pm
I was told the car is in 2nd gear, not 1st. 2nd gear is the Chrysler "limp home" gear.
Bob with same problem.
Old 07 Dec 2011, 09:08 pm
Bob with same problem, get it to a dealer or transmission shop to diagnose the problem. There's nothing you can do without knowing what the exact problem is.
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
