My PT is a 2002 LE, black w/purple flames, still new - only 3500 miles (only 183 when I bought it). I've only done 2 things with him - installed a K&N air filter, and changed to synthetic oil at 2200 miles. At first I was hoping the stutter, or miss, would go away. You know, dirty gas or something. Notta. Oh yea - it's a 5 speed. It doesn't matter what gear I'm in, the miss is there. Worse with a/c on. I put the oem filter back in but it still misses. Took it to the dealer, and all they said was it didn't show on the computer. Can anybody help? Thanks so much!
Garlin,
Did the stutter start right after the installation of the K&N? Did you put in in yourself? Maybe a connection was left off. There's two connections that go into the filter...one is a sensor that measures the air density and has a very small delicate tip, check to see if that has broken off. The other connection is a feed back black plastic tube that runs from the right side of the engine to the filter. Make sure it's connected well into the K&N tube. Just something to check...good luck.
What rpm are you noticing this @ ? It's it the same rpm in all gears ? Could possibly be plugs/wires/coils ... if it gets bad enough you should see the engine symbol light then you'd have a code to pull/look @ .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp |
| "Mysterious" turbo engine noise...??? | Gary04GT | Turbo Performance | 76 | 21 Aug 2006 08:28 am |
| Review: $2200 for a NA replacement engine PT | Ctown | General PT Cruiser Discussions | 8 | 24 Jul 2006 01:08 pm |
| Engine problem | BORICUA | Tech & Performance Forum | 49 | 03 Apr 2006 05:15 am |
| miss under long and heavy throttle loads | pppt03turbo | General Turbo Discussions | 19 | 26 Oct 2005 08:09 am |
| engine missfiring | sandylolee | Turbo Performance | 13 | 08 Jan 2004 11:02 pm |
