PT Cruiser Forum Car Videos
Car Rims
Help! Broken Timing Belt
  #11 (permalink)
Old 11 Apr 2008, 02:46 pm
cool_zero cool_zero is offline
Default Re: Help! Broken Timing Belt
Word of advice - When they change the timming belt they will probably want you to change the oil pump at the same time (which is not a bad idea because you will be in there anyway) the pully on the front of the oil pump is a PRESS ON pully - it requires a special tool from Mopar to install it properly. I had a mechanic do my belt and then 25,000 miles later that pully wore a hole in the front of my oil pump!!!!! Just a heads up - if they tell you different fine someone else to fix you car!!!!
  #12 (permalink)
Old 30 Apr 2008, 01:45 am
scoobysteven scoobysteven is offline
Thanks to all who helped me with advice regarding belt replacement. Turned out, no bent valves. Just replaced the belt, pump, and car runs fine.
  #13 (permalink)
Old 30 Apr 2008, 06:47 am
Pat1USMC Pat1USMC is offline
What did the final cost come to? I have about 87k in my 2001 so I am thinking about getting it done soon...
2001 Inferno Red LE
Whipple Supercharger, BTG springs, BTG cat-back exhaust, B&M short shifter, APC eurotails, Chrome Grille, fuel door and vent knobs, painted bumpers, mirrors, airdam and center console, cueball shifter, Polk audio system w/ XM
  #14 (permalink)
Old 30 Apr 2008, 09:08 am
Guy in San Diego did it for $350. Whatever you do, don't wait until it breaks.
  #15 (permalink)
Old 01 May 2008, 07:01 am
Guys, I have a question, it was mentioned hear that when you change the timing belt you should do the oil pump as well, I thought you were spposed to change the water pump when doing the timing belt? I never heard about the oil pump? please clarify..............gary
vB code is On
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 4 01 Mar 2008 08:04 pm
Timing Belt Replacement MarkB Tech & Performance Forum 8 10 Nov 2007 03:16 am
when to change Timing belt ? Ctown General PT Cruiser Discussions 4 19 Jan 2006 10:39 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 2 09 Jun 2003 12:17 am
  Loans | Personal Loans | Myspace Comments | Loans | Mortgage
