PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Help! Broken Timing Belt
Old 07 Apr 2008, 05:49 pm
scoobysteven scoobysteven is offline
Default Help! Broken Timing Belt
The timing belt on my girl's 2001 PT Cruiser broke. Car just quit, no banging. What are the chances of damage, bent valves, etc?
Old 07 Apr 2008, 06:14 pm
lakersfan1 lakersfan1 is online now
Default Re: Help! Broken Timing Belt
Slim to none, unless there was a cause other than old timing belt.
Old 07 Apr 2008, 06:16 pm
So you are saying there would be damage?
Old 07 Apr 2008, 06:33 pm
CREWZIN CREWZIN is offline
As a last consideration, timing belt replacement should be performed at the recommended interval to prevent possible engine damage. Several DaimlerChrysler engines do not have free-wheeling provisions. In other words, if the timing belt fails, an ascending piston(s) can strike a valve(s) in the open position, causing extensive and expensive engine damage. The 1.6L SOHC, 2. 0L SOHC, 2.0L DOHC and the 3.5 V6 all fit into this category. The 2.4L DOHC, used in the minivans, PT Cruiser and Sebring/Stratus, however, is a free-wheeling engine. A broken timing belt will just leave you on the side of the road with no additional engine damage. The 2.4L is a free-wheeling engine when it comes to piston to- valve clearance. However, the valves may hit each other should the timing belt break.
Old 07 Apr 2008, 08:37 pm
Thanks bro! I think my engine might be OK
Old 07 Apr 2008, 10:17 pm
bobs turbo pt bobs turbo pt is offline
let us know how you make out good luck !!
Old 07 Apr 2008, 10:42 pm
I will for sure, and thanks for all your help!
Old 08 Apr 2008, 07:35 am
Hooligan Hooligan is offline
How many miles did the car have on it? Was it past the recommended mileage to have the belt replaced?
2006 Black Limited, NA, Sirius; chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty cover; Champion 7570 Platnium Plugs (.040); MOPAR Performance Wires; 2005 Chrome GT MOPAR wheels; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot rest Pedals, Chrome side spears.
Old 08 Apr 2008, 10:13 am
It had 111K, and no the belt has never been changed. The car belongs to my female friend. Some things are predictable, and this event is no different.
Old 08 Apr 2008, 02:12 pm
Recommended change between 90-100,000 miles.
vB code is On
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 4 01 Mar 2008 08:04 pm
Timing Belt Replacement MarkB Tech & Performance Forum 8 10 Nov 2007 03:16 am
when to change Timing belt ? Ctown General PT Cruiser Discussions 4 19 Jan 2006 10:39 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 2 09 Jun 2003 12:17 am
  Loans | Advertising | Mobile Phones | Car Insurance | Cheap Car Insurance
