PT Cruiser Forum Car Videos
Car Rims
P0304 question
Old 11 Apr 2008, 06:40 pm
4SPEED 4SPEED is offline
Default P0304 question
I keep getting intermittent P0304 codes and was wondering if the 2 coils could be switched therby if the #4 coil was bad it would now show a P0302 or P0303 code. Then I would know for sure without having to speed money needlessly other than for a set of plugs.
thanks guys
Old 11 Apr 2008, 09:42 pm
Cartman Cartman is offline
Default Re: P0304 question
there is only 1 ignition coil, but it has 2 sides. if you are reading a bad side, then the whole thing needs replacement. replace the plugs and wires while you are at it.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 12 Apr 2008, 09:28 am
how do you test a coil to find out if there is a bad side?
Old 12 Apr 2008, 03:43 pm
I dont have a testing procedure handy, but the coil fires two cylinders at the same time. coil 1 fires cyls 1 and 4, coil 2 fires cyls 2 and 3. if you are having a missfire on only one cyl, check your plugs/wires first.
Old 12 Apr 2008, 04:51 pm
And the stock ignition wires are crap. On both my PTs, they started to die at about 20,000 miles.
vB code is On
PT / SRT-4 Rear Sway Bar Question Maxxam Turbo Wheels/Suspension/Handling 11 13 May 2008 02:29 pm
Engine Question! b0b88 Tech & Performance Forum 7 03 Apr 2008 05:27 am
Question about my Turbo. JMan General Turbo Discussions 4 18 Mar 2008 07:35 am
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
dumb question of the day !! bobs turbo pt General PT Cruiser Discussions 7 21 Feb 2003 08:01 am
  Remortgages | Loans | Web Advertising | Cheap Samsung LCD TV | Loans
