PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
04 pt cruiser question
Old 11 Apr 2008, 08:11 pm
resiurcPT resiurcPT is offline
Post 04 pt cruiser question
I've noticed that when the motor is running and with the a/c on, the car trys to die, but keeps running, but will die if you don't apply more gas. Would this be caused by low freon, or somthing
else? I thought it may be the fuel filter but with the a/c off it runs fine.
Thank you
PS
Which line is the low side for putting freon in?
On mine there is a place on top and the other is lower down in front of
the motor. Is it the one on top?
Old 11 Apr 2008, 10:26 pm
SRG SRG is offline
Default Re: 04 pt cruiser question
Well, you haven't given us a lot to go on, but let's see,
-old, dirty spark plugs? (how many miles?)
-bad gas? (try some dry gas/stp fuel system cleaner)
-old spark plug wires
-clogged fuel injectors?
-dirty air filter?
I don't think the freon level effects how well the car runs, if the level gets too low, the pressure switch won't let the compressor run.
just guessing here....
srg
Old 11 Apr 2008, 10:47 pm
I'm so sorry, its a 2.4L non turbo, stock.
out of the 5 answers it sounds like it could be the wires, Haven't changed them
since I bought the car. I put new plugs in not to long ago but did not put
new wires on. The car has 81,000 miles on it.
Old 12 Apr 2008, 04:47 pm
By all means replace the wires. Also could be the idle air controller (IAC) - you can take it out and clean it. Do a search on IAC.
Old 12 Apr 2008, 09:02 pm
I went and changed the wires and that took care of the problem, Its
running a lot better now. Test drove it and it seems it has more power and
idles better too. Thanks so much for the help.
Old 13 Apr 2008, 08:14 am
bobs turbo pt bobs turbo pt is offline
welcome to the board !! glad you got the car running better
Old 15 Apr 2008, 07:18 pm
Glad you solved your problem.
This forum is great!
vB code is On
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
2007 PT Street Cruiser Announced skylight PT Cruiser News and Rumors 0 16 Aug 2006 08:47 am
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 9 28 Jan 2004 09:39 pm
  Credit Cards | Budapest Accommodation | Personal Loans | Credit Card Consolidation | Mortgage
