1. What cam did you buy?
->Crane #12 ordered almost everything from Howell Automotive I thought about going to a #16, but this car is an automatic. Was afraid I might run into idle problems and would have to install a stall converter. The SRTs that I have seen with those cams or bigger are really lumpy. 2. What were the lift/duration numbers versus what the stock NA PT has? -> I forget the specs on stock but it was a defined increased in durration 3. I see (in your photos) that the PT pistons are Tir-angle topped with valve releifs. How did you know how much head to deck off without crashing the pistons into open valves? -> The stock pistons from my understanding still allow for free passage in case of timing belt failure. Knowing this, I had all the room in the world to shave. I did .020 but really would like to have pushed .040, except a timing belt failure now would probably allow them to hit. 4. How do you think your mileage has been affected with the new cams & porting? -> It dropped from 21 to 17.5, and that is driving normal. No peddel mashing. But, I have not tuned it on the Dyno nor added the Neo yet. I assume that will bring it back closer to 21 again. |
>(Tom) So according to your numbers you dropped about 16%. I'm guessing you probably did some pedal mashing *winks*. C'mon! How can you possibly have just modded your car and NOT have let loose a few times...? *laughs* I'm not sure what type of tuning you're talking about? What else can be done with the equipment you have?
Also, any chance you can record a digital file of what your engine idle and revving sounds like? I'm sure myself and others are curious. Is it possible to post sound (MP3 or WAV) files here? If not you can email it to me. I have adjustable cam gears on the car. They are currently set at Zero, but with the shaved head they are probably retarded at least 1 degree. Shaving the head shortened the drive side of the belt. Most common advice I have seen is to advance the intake by 2 degrees and retard the exhaust by 3. I figure it is going to cost me about $300 in dyno time to tune them. The Neo shuold also lean out the motor giving it more HP and better gas mileage. Well, the better gas mileage is while there is no peddel mashing. :-) You are correct, it is much more dificult driving the car without doing the geforce thing from a stop light. I will video the dyno and record how the car sounds. I am amazed at how deep it sounds, no Honda whinning or bees in a can, the 2.5" glass packs and lake pipes gives it a really deep, solid sound. sitting at idle, every asks "That is no PT motor, what kind of engine did you put into it?"
I set a budget of $6,000 to do both the motor and body work. I was able to get some super deals on a Pteazer hood for $250 and my neighbor owns a small body shop so I have been able to streatch that budget a long ways to get most everything you can for a NA PT. I would love to see some more strong NA PT's out there and I hope my tests can help. |
Have you ever thought of doing a functional ram air setup? That would help pick up some HP on the top end. If you were to make the airbox fully airtight with a good hood, or put on a hoodscoop and plumb in air lines you should be able to shove a lot of air in at speed. If the n/a engine is indeed faster off the line, then ram air could help hold a turbo off for that much longer.
The only thing I'm not sure about is I think the PT uses a MAP sensor and I don't know if it will see all the air flow or not since it just senses barometric pressure. I know MAF sensors work better with ram air. Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, Keystone ram air hood, 6000k 55w HID high beams, 6000k 35w HID fog lights, new stone chips every day to add character. 2007 Suzuki King Quad 700 4x4 for when the road gets bumpy. |
Based on your project (which has me REALLY excited for my NA PT) I'm planning on mimicing your actions to some degree. I'm looking to do the following:
![]() I'm curious about something however: I don't have adjustable cam gears (only the stock ones). So I'm not understanding why you said you needed to tune in the cam advance/retard based on the decking of the head retarding them? If the cams are timed together and set a 0 degrees then when you put the belt on, they're still set at 0 degrees....right? What am I missing here? Do you think I'll need to do this as well with the slightly milder #10 cam? (see specs. vs. stock below) The #10 has much higher lift than stock, but the duration is only 6 degrees longer. I'm thinking I might be able to live with the stock cam gears based on that?Crane #10 Cam- Part Number: 193-0010 Grind Number CHR-242-10 Advertised Duration Intake/Exhaust 242 / 242 Duration @ .050 Intake/Exhaust 200/200 Lobe Separation 110 Gross Lift 354/354 Stock Cam - Part Number: Stock Cam Specs BACK TO LIST Advertised Duration Intake/Exhaust 248/248 Duration @ .050 Intake/Exhaust 194/196 Lobe Separation 113 Gross Lift 325/259 I understand the concept when you said this: "Most common advice I have seen is to advance the intake by 2 degrees and retard the exhaust by 3" - to obtain maximum HP and efficiency (MPG). Is that advice SPECIFIC to the #12 cam? Which I'm guessing you have some experience or know people who have modified 2.4L NA's with these cams before, right? Where did you find the info, or did you crunch some numbers yourself? You rock man! This project is and will be fun! Thanks for your replies.... Tom
On an OHC engine the cam sits on the top of the head. If you shave the head you lower the cam in relation to the head. This means your chain/belt is now too long. This can make it so that if you line the cam up on one cog vs another it is either too far advanced or retarded.
I think that's it anyways. ![]() Ben
[QUOTE=Deathstar;231259]Ported and shaved Heads + Crane 12's are installed on the car now. We shaved them .020, bringing the compression up a full point we think. I believe I can feel the difference in the seat of my pants, but want to get it to the dyno first. The new lake pipes are LOUD! I am dumping the header into a Thrush glasspack then splitting it out the sides in front of each rear tire. For a NA, it is starting to get pretty mean. More pics of the car to come soon.
QUOTE] As I stated before your project has become the spring board for my own. So with that (since you've been so helpful already) I have a few specific questions/concerns about my own project NA PT. - I'm looking to do the following to have some more fun with my PT(hopefully adding about 20+ HP and at 20+ ft lbs of torque in the process):
Crane #10 Cam- Part Number: 193-0010 Grind Number CHR-242-10 Advertised Duration Intake/Exhaust 242 / 242 Duration @ .050 Intake/Exhaust 200/200 Lobe Separation 110 Gross Lift 354/354 Stock Cam - Part Number: Stock Cam Specs BACK TO LIST Advertised Duration Intake/Exhaust 248/248 Duration @ .050 Intake/Exhaust 194/196 Lobe Separation 113 Gross Lift 325/259 Will my stock CAM gears work with this cam? (I’m hoping so since the duration is only 6 degrees longer than stock) I shouldn’t need adjustable cam gears right? Crane clams “good idle quality” with this cam, but is that “good” for a cammed up motor or good compared to stock? Any experience with this? Will this cam raise my redline or is that determined by the computer? Will the stock rings hold up against the increased compression? Or should I expect increased oil consumption? Will my PT computer and injectors be able to maintain the proper A/F ratio? (the cams not that wild so I’m hoping so, since you're already running a #12 crane cam with stock PT injectors/computer) Will the engine require some level of “tuning” to run well, or will the computer be able to make the adjustments on it’s own? Thanks guys I’d love to hear your feedback/opinions! Tom
Crane clams “good idle quality” with this cam, but is that “good” for a cammed up motor or good compared to stock? Any experience with this? Will this cam raise my redline or is that determined by the computer? Will the stock rings hold up against the increased compression? Or should I expect increased oil consumption? Will my PT computer and injectors be able to maintain the proper A/F ratio? (the cams not that wild so I’m hoping so, since you're already running a #12 crane cam with stock PT injectors/computer) Will the engine require some level of “tuning” to run well, or will the computer be able to make the adjustments on it’s own? My #12 idles good, just a enough lump to make it sound different, but does not hesitate any when reving up from idle. The stock gears will work with the cams, you just will not be able to fine tune them. I have not got onto the dyno yet, but I am guessing the -3 exh, +2 intake will make them perfect. But even at zero, they are surpassing stock performace in a big way. The cams will raise your redline power, but not the redline cut. The computer will kill the engine before it reaches maximum power now, which is around 7,200 RPM. Your stock internals, computer, injectors are fine. The injectors are good for some pretty good HP and the computer is pretty smart. Only thing is that it will always try to run rich to be safe. A AFC computer will allow you to lean it out for a little more power. I am getting a lot of my tunning info from the SRT guys who are building lots of power in their cars. We have the same motor as them but there are a lot more of them racing than we are. Many of the SRT guys have tried to convice me to go Turbo, but I felt that my project car is more "old school" in styling. I wanted to keep the motor NA, loud and quick to rev on the power. That is a great combination for street performance. Not many places other than the track, to kick it for more than 15 seconds anyway. Stop light to stop light in my town is much shorter than that. But the shock on the guy's face next to me who has a turbo is great. He does make more top-end power than I do, but never gets to use it. I launch, make lots of noise and already slow down for the next street before he gets to make any power. :-) Now on the highway, it is a different story, I can kick it, quickly move ahead by a good car because of the quick power, but about 3 seconds later a well built 50trim turbo car will blow by me like I was nothing. Last edited by Deathstar; 04 Jun 2008 at 03:54 pm. |
Besides, with almost $6k into my car, it had better do what it does or my wife would kill me. ![]() Still, your ride is going to be special. My wife has an automatic '04 na PT and while being a great car to cruise in it is slower than frozen mud. You are going to surprise a lot of people. There would be a lot of people over at PTCrew.com - Learn it or Burn it. with na PTs who are looking for some more punch. If you haven't been there, there are a lot of PT gearheads who hang out there.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
| Cylinder Head Question for a 2003 GT | customer20 | General Turbo Discussions | 15 | 23 Dec 2007 10:47 am |
| wire harness for new head unit | ckanders | General PT Cruiser Discussions | 3 | 28 Mar 2007 03:31 pm |
| Head porting? | MEXICANPT | Turbo Performance | 8 | 07 Mar 2004 09:32 am |
| Solid Head bolts for the GT Turbo? | Airbillster | Stage Turbo Kits | 7 | 26 Dec 2003 11:45 am |
| Head bolts for the Turbo? | Airbillster | General Turbo Discussions | 11 | 16 Dec 2003 11:05 am |
