| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
CARTMAN Thanks for the response..Engine wiring harness has been repaired..Traced LB/WT wire from fuse panel fuse #11(ENG MOD/ABS-TRAC) to the PCM pin #20. With the connector disconnected and ignition key on LB/WT wire reading 12.5 volts and fuse is good. Also all connectors on engine disconnected. PCM connector plugged back in, battery connected and key turned on, the fuse blows. Could I have a bad PCM causing the fuse to blow??
that fuse also powers the fuel pump relay and the ABS controller. replace the fuse, and disconnect the abs controller connector and remove the fuel pump relay. if the fuse doesnt blow, put the relay back in. if it blows, the relay or the wiring harness for the relay is bad. if it doesnt blow, connect the abs controller. if it blows then, the abs controller may have an internal fault and may require replacement or its wiring harness is damaged. of course, if all that is disconnected, and just the PCM is connected, and the fuse blows, yeah id say its the PCM. but start with the cheap stuff first. also check to see if you have the correct fuse in that location, it should be a 10 amp. good luck.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs. Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways. |
Thanks, Checked - No ABS, pulled all the relays in the PDC, plugged connector into PCM, connected battery, key on, fuse blows... So, I'm assuming the PCM is bad. Also ohmed pin 20 in the PCM to the case, it's indicating grounded. Is there any way to check (continuity or otherwise) the engine wiring harness that would cause the PCM to short? Hate to put another PCM in and blow it too. Would a PCM connector pin diagram help to check each circuit in the engine harness? Just pulling straws right now,,,,
youve still got a damaged wire in there somewhere. pin 20 shouldnt be grounded. that direct short to ground would blow that fuse. that particular circuit goes all over the engine compartment from what i can tell.
Cartman
Chased a lot of wire last several days to no avail, I was about to give up and let a shop look at it until I disconnected the EVAP PURGE SOLENIOD. Hooked everything back up and tried the scanner,,,It got some codes..P0118 P0340. Missed the temperature sensor connection and swapped the cam position sensor. The motor finally started but only ran for 10 seconds. Acted like it was running out of fuel each time. Tomorrow I'll chase that... Anyway what I wanted to say was ...THANKS for steering me in the right direction. ![]() |
no problem
| Ciggy lighter & Power outlet not working -all fuses fine. | swisstony10 | Tech & Performance Forum | 2 | 12 May 2008 07:18 pm |
| Blowning fuses | DragAsp | Tech & Performance Forum | 1 | 15 Apr 2008 12:14 am |
| fog lamp fuse blowing | smilanatu | Tech & Performance Forum | 10 | 29 Jan 2008 09:53 pm |
| fuses | alice | Stage Turbo Kits | 7 | 07 May 2005 10:08 am |
| Example of NO2 Blowing up in your face | VellianPT | Non-PT Discussions | 5 | 14 Apr 2005 03:13 pm |
