PT Cruiser Forum Car Videos
Car Rims
The Tranny, she blown :(
Old 16 Apr 2008, 08:07 pm
03TurboGT's Avatar
03TurboGT 03TurboGT is offline
Angry The Tranny, she blown :(
Well I kinda figured the ol cruiser wouldnt be able to put up with my racing habits for too long. It doesnt upshift and anything past half throttle, it just slips. At first the check engine light came on, it stuck to 2nd gear and basically went into limp mode. Im taking it in on friday to see the grand damage. I never brake torqued it once or any neutral drops, just went though the gears normally. Didnt even last a year. WHat a shitty trans.
A stupid question must be asked though. Is it a total waste of time and money for a 5spd swap? I have to ask, since the auto let me down.
Bryn-
'03 Turbo H.O.
with K&N Intake
Stage 2 Jet Chip
NGK Iridium Plugs
Xenon Headlights
10.5mm Racing Wires
Mopar BOV Conversion
4 Drilled/Slotted Rotors
180W Infinity 6.5" 2-way's
General Performance 215/45R 17's
Mopar/Borla Dual Cat-Back Exhaust
Old 16 Apr 2008, 08:17 pm
fastmdpt fastmdpt is offline
Default Re: The Tranny, she blown :(
Betcha the OD section is gone,, pretty typical for the 41te, AJ Berge is working on the trannys,,, the only problem is he has received a bunch of junk OD hubs. He is not building trannys right now because of it. When you get the tranny done,,, do not boost in OD.
Tom
Old 16 Apr 2008, 08:28 pm
03TurboGT's Avatar
That sucks. there was deffinate boosting in OD before. Is that what wouldve caused it? And would a regular rebuild fix the OD section?? thanks
Bryn-
'03 Turbo H.O.
with K&N Intake
Stage 2 Jet Chip
NGK Iridium Plugs
Xenon Headlights
10.5mm Racing Wires
Old 17 Apr 2008, 04:42 am
The problem is this,,, in OD you have four driving clutches engaged,(I may have it backwards, might be holding,, but the theory is the same) when you start putting boost to it, it usually rips the outer dogs off of the hub, the tranny usually goes into limp mode, tranny indicators will all be lit, and car won't go past second gear.
Stock rebuild will get you through for a while, a lot of places put a fifth clutch in the OD, which does help, AJ put SIX in my latest tranny, and I have been "testing" it but AJ says he will probably go back to five. He also does work with valve body, and other areas of tranny. Even with his rebuilds AJ says NEVER boost in OD, put the car in autostick, pull it back to third make pass or whatever, when you get back to "normal cruise" let it go back to OD.
AJ has my car right now,,, as I blew the differential a couple of weeks ago. I can find out what his status is as far as doing rebuilds,, but the problem is he is so busy now,, even if he has solved the hub from China issue,, you probably would not see a tranny for a month or two
IMPORTANT!!!!! IF YOU GET A TRANNY DONE FROM ANYONE,,, MAKE SURE THEY FLUSH THE TRANNY COOLER OUT!!!!!! You'd be amazed how much junk WILL get lodged in it.
Tom
Old 17 Apr 2008, 06:49 am
03TurboGT's Avatar
Perfect. Thanks for the info & I will be sure to post exactly what they found!
Bryn-
'03 Turbo H.O.
with K&N Intake
Stage 2 Jet Chip
NGK Iridium Plugs
Xenon Headlights
10.5mm Racing Wires
Old 17 Apr 2008, 07:04 am
Johns Steel Blue's Avatar
Johns Steel Blue Johns Steel Blue is offline
I am sure the "racing habits" did not help. Hope the damages are not too "billfold draining"
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
Old 17 Apr 2008, 07:51 am
bobs turbo pt bobs turbo pt is offline
let us know how you make out good luck
vB code is On
3 tranny overhauls and I now need a new one? koozy General PT Cruiser Discussions 4 31 Jul 2007 01:55 pm
i think tranny is bad g00zor General Turbo Discussions 9 08 Jan 2007 07:29 pm
Tranny cooler? sawdust123 General Turbo Discussions 2 07 Jun 2005 09:14 am
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Burned up 2nd and 3rd gears in Autostick tranny. Rainman General Turbo Discussions 6 16 Mar 2004 01:40 pm
  Loan | Zappos Coupons | Myspace Images | Debt Consolidation | Loan
