2005 pt overheat no engine codes
Old 19 Apr 2008, 04:47 pm
Default 2005 pt overheat no engine codes
my girlfrind has a 2005 pt and its overheating. no engine codes come up but the check engine light blinks 9 times and then stays on after that. i can't find anything wrong. anyone have an idea?
Old 20 Apr 2008, 09:17 am
Default Re: 2005 pt overheat no engine codes
hi, welcome to the board ,water pump ?? while car is running do you see the liquid in the radiator moving ?? where is the liquid coming from while its over heating ??
Old 20 Apr 2008, 03:34 pm
There could be a number of reasons why it's verheating but the main one a lot of owners have is that one or both fan motor speeds have burn out. Two other reasons are water pump (mentioned above) and a malfunctioning or broken thermostat.
Old 24 Apr 2008, 01:10 pm
And most expensive of all, a clogged radiator or bad head gasket.
Old 21 May 2008, 01:57 pm
OK so the car has been sitting for about 2 months and i finally got 2 codes to pop up they are 0480 and 0481, Cooling Fan Relay 1 Control Circuit and Cooling Fan Relay 2 Control Circuit. So is this bad relays or a wiring issue? thanks for the input.
Old 21 May 2008, 02:06 pm
The fuse box under the hood has both the High speed and Low speed fan relays. I'd almost bet my annuity check that both relays wouldn't go out at the same time but stranger things have happened. As far as maybe it being a wiring issue, I don't think anyone hear could make that call. Start with the relays. Clear the codes and see what happens.
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine Light Codes Rob in tx Tech & Performance Forum 2 06 Mar 2005 03:55 pm
Engine codes Kroozah Tech & Performance Forum 8 31 Jan 2005 01:22 am
