| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
my '02 Dream Cruiser has become a nightmare . The recurring problem is when I turn the ignition there is only a click , the engine does not even crank . The battery is okay but have replaced the starter 2x last 5 months and it still happens . Any suggestions appreciated .
Check the battery cables, ignition coil (power pak whatever it is).
Good Luck, let us know; srg |
thanks for your help , it's appreciated . When it happens again i'll have to try some of these ideas and then let you know.
It's more than likely the battery cables have corroded. They are really sorry cables.
I had the same problem on my PT and as others have stated it turned out to be the cable from the battery to the starter had gone bad. I replaced all battery cables and the car has been perfect since. Hope this helps.
2002 Inferno Red Limited Edition|K&N FIPK|Bassani Exhaust|17x7 Eagle Alloy Chrome 192 BFG KDW| 225/45/17|Progress Sway bars|Eibach Lowering Springs| Tokico Blues|Strut Tower Brace|Hood Struts|Color Matched Bezel|Lighted Entry Guards |
Welcome.
When you say the battery is okay - do you know that for a fact? Sear,KMart. etc. will test for free. If you're handy and agile, measure the cable going to the starter and go to AutoZone, AdvanceAuto, etc., and look at battery cables - be sure and get the thickest or even use two, and replace what's there.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
| 2002 PT Intermittent Starting Problems, Very Long, Goes Back 3 Years | BeBeCroozer | Tech & Performance Forum | 4 | 19 Dec 2007 10:36 am |
| ARRG!! Odd problem and loose sensor | Jason_L | General Turbo Discussions | 4 | 18 Mar 2006 01:40 pm |
| I think I'm having a power steering problem! | lumofny | Tech & Performance Forum | 5 | 18 Jan 2005 01:12 pm |
| Unknown RPM surge problem (manual) | Ctown | Tech & Performance Forum | 4 | 26 Dec 2004 08:48 pm |
| Sqealing problem in 2003 PT Cruiser | labradorlover | Tech & Performance Forum | 21 | 31 Dec 2003 03:44 pm |
