| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I was wondering how well an SRT4 t850 transmission would bolt up to a PT engine. I currently have a 5 speed and it is dying so i was looking to upgrade. The only things I can think of are how well it will bolt to the engine and how well the linkage will hook up. I have heard that the SRT 850 and the stock 350 are able to bolt up to the same things from another member. I appreciate any help!
01, Inferno Red, PT LE, 5-speed Manual. EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads Pictures of my PT |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Well i didn't figure it would be indestructible, but it has to be better than the stock PT one, I highly doubt that Dodge/Chrysler would just make 2 equally strong/weak transmissions for cars of different performance ranges. As for the length, do you know how much longer it is and where the clearance issues are? I am just doing research for when I pull mine.
I was pretty sure I had come across a guy on ptcrew that has done the swap. He went from a N/A auto to an SRT-4 engine and tranny. I can't remember what the heck his name was, I'll see if I can find that thread.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character. 2007 Suzuki King Quad 700 4x4 for when the road gets bumpy. |
I wouldn't put a whole lot into a T850 being an 'upgrade'. There are plenty of stories on the SRT forums of T850s going out at ridiculously low milage with fairly stock power. I don't know if the T series trannys are blowing because of power per se anyways.
If I wanted to put down 300HP, personally I'd just use a quality clutch with a soft engagement to keep tranny shock down, and put in Booger bushings to make sure I don't miss any shifts. Anyways, if you did a T850 mount in the PT you may need to get custom half shafts made, which will run you $1000 easy. Just not worth it for swapping for a tranny that has a worse record than ours. |
| Transmission Plant Drives Optimism | skylight | PT Cruiser News and Rumors | 3 | 27 Jun 2007 02:14 pm |
| Manual Transmission Fluid Change | matt87951 | Tech & Performance Forum | 4 | 06 Jan 2006 07:12 pm |
| transmission | lotta | Tech & Performance Forum | 6 | 29 Sep 2005 08:44 pm |
| Transmission fliud - B&M Trick Shift or not? | snakepitt1 | Tech & Performance Forum | 8 | 22 May 2004 06:58 pm |
| "Internal Transmission Problem" ??? | yobiebs | General Turbo Discussions | 18 | 21 Oct 2003 11:17 pm |
