Another A/C problem
Old 30 Apr 2008, 09:48 pm
Post Another A/C problem
On my 04 non turbo 4.7 pt. I am having trouble with the a/c not taking
any freon, I have the hose connected to the low side. The compressor is
kicking on and off while the a/c is on. I noticed that when the cooling
fan came on the air would get cooler and when the fan shut off it blew warm
air. I have a R-134 recharge hose with a gauge handle. The needle
would go over in the red meaning overcharged and when the cooling fan
comes on the needle would move down in the green sayin filled. I hope
someone can make some sence of what I'm trying to explain.
Old 02 May 2008, 01:53 pm
Default Re: Another A/C problem
My first take is that you don't have enough r134 in the system to keep the compressor engaged. The low pressure switch keeps turning it off. You have to jump the low pressure switch to keep the compressor turning to fill the system.
Old 02 May 2008, 10:37 pm
Ok I will try that and see what happens.
Thank you Cal
Old 03 May 2008, 10:57 pm
Cal, where is the low pressure switch located?
Old 25 Jun 2008, 08:36 pm
TTT TTT
Old 25 Jun 2008, 09:41 pm
There's 2 switches that I know of....
Pressure Cycling Switch
Old 25 Jun 2008, 09:56 pm
Thank you Crewzin, is it the one in the bottom pic? i unhooked the pressure
cycling switch and used a jumper wire but nothing happened.
Old 25 Jun 2008, 10:03 pm
Sorry, I don't mess around with AC. Not sure which switch it is. CAL mentioned the Low Pressure Switch but the Haynes manual has no mention of that particular switch.
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
Running out of patience with CEL problem coolvirus General Turbo Discussions 5 19 Mar 2007 10:42 am
stage 1 install problem gooberff Stage Turbo Kits 6 29 Jun 2005 12:22 am
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
