Transmission linkage "temporarily fixed"
Old 09 May 2008, 08:07 am
PTmodrod's Avatar
Default Transmission linkage "temporarily fixed"
My trans was having a lot of trouble going into first and third gear and day by day, it was getting worse. Finally i ripped out my center console and took a look at the linkage at the shifter end. perfectly fine. so i checked it where it connects to the transmission... The bushing that usually holds the linkage to the peg was, for lack of a better word, shrapnel. There was about half an inch to 3/4 of an inch of play before the linkage moved the peg. I ripped out the chunks of old bushing and found a way to temporarily fix it! I used a small bushing that fits snugly inside the loop at the end of the linkage and over the peg, but obviously it would not stay in place, as the R clip was missing and thebushing was not held in pace by anything but friction so! on top of that i put a large washer and held it all down with a loop of coat hanger wire as i didn't have any R clips. This is only a temporary fix, but i thought you might get a kick out of it.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
Transmission Plant Drives Optimism skylight PT Cruiser News and Rumors 3 27 Jun 2007 02:14 pm
transmission lotta Tech & Performance Forum 6 29 Sep 2005 08:44 pm
Transmission, linkage or clutch help coolzero Tech & Performance Forum 2 12 Sep 2004 10:42 pm
Transmission fliud - B&M Trick Shift or not? snakepitt1 Tech & Performance Forum 8 22 May 2004 06:58 pm
