Throttle body install 06 touring
Old 10 May 2008, 07:07 pm
Question Throttle body install 06 touring
Does anyone know how hard it is to install a throlle body?
Old 10 May 2008, 07:26 pm
Default Re: Throttle body install 06 touring
??? Do you mean a throttle body spacer, or a new throttle body?
If it's a spacer ...forget it, waste of money! If you need to put on a new throttle body (for some reason, it's pretty easy, just a couple bolts after taking off the air intake tube, but you should tighten down the bolts after installing a new TB to the correct specs using a torque wrench.
Old 10 May 2008, 09:21 pm
Smile Re: Throttle body install 06 touring
A spacer. Does it increas the MPG? I'm a newbie when it comes to mods.
Old 10 May 2008, 09:26 pm
The TB Spacer might help on some cars ....mostly carburetors, but will do nothing for the PT.
Old 10 May 2008, 11:15 pm
the intake runners are already rediculously long on a PT, so adding a spacer will give you no noticeable effect either HP or gas mileage wise.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 14 May 2008, 10:29 pm
Deathstar's Avatar
I believe some of the spacer companies are stating that thier spacer makes more power because it causes the intake air to swirl in one direction. I have not seen any dyno proved power from a spacer on a PT. Howell will port your TB to 55mm for $100. That is a proven power increaser, I am sending mine off shortly if you want to know how well it works.
Old 16 May 2008, 10:56 am
Thank you, please let me know haw the TS works...
Crane Cams / throttle body WinDaddy Tech & Performance Forum 4 26 Sep 2007 04:09 pm
straw went flying into throttle body churdiales Tech & Performance Forum 14 01 Sep 2007 07:14 pm
AT Throttle Body in 5 Speed mvandale Turbo Performance 3 05 Dec 2006 12:03 am
POWERAID Throttle Body Spacer - Works?? matt87951 Tech & Performance Forum 17 23 Aug 2006 09:35 pm
Airaid Airmax and throttle body spacers Robster Tech & Performance Forum 22 22 Jul 2004 08:12 pm
