Tune-up ?
Old 11 May 2008, 10:53 am
Question Tune-up ?
My cruiser has 30,000 miles on it. I would like to know what spark plugs, wires and coil to install? Aftermarket parts? Any other possible tune-up ideas?
06 Touring
Manual
~30,000miles
Old 11 May 2008, 01:01 pm
Default Re: Tune-up ?
Your coil should be good for the life of the car, leave it alone. Any decent set of wires except what Chrysler sells will do. A lot of us went to the Champion Double Platinum plugs #7570 gapped at .040in. Be sure to use dielectric grease on the plugs wires, anti-seize on the threads of the plugs.
If you can afford it, switch to synthetic oil. Good for the engine and might even give you 1 or 2 more MPG.
The owner of the forums (Skylight) put a "sticky" in the Teck & Performance part of the forum. Use that as your guide to changing the plugs and wires. You won't have to do some of the instructions and it pertains to older PT's but most of it's the same.
Old 11 May 2008, 03:28 pm
Are you supposed to change the spark plug wires? I'm used to working on older cars.
Old 11 May 2008, 03:33 pm
YES, definitely, especially on a PT Cruiser. The stock wires don't last very long and cause problems to countless owners.
Old 11 May 2008, 03:44 pm
Any recommednations for sprak plug wires? I asked about the coil, I have a free one scream demon from a freind? So don't install it?
Old 11 May 2008, 03:50 pm
Since it's FREE, go ahead and install it, can't hurt. Just didn't want you to put out any money for it because the stock coil lasts almost forever and it puts out more than the PT needs so there's no justification for the expense.
Most auto stores (Auto Zone, Pep Boys Advance Auto etc.) carry sets of wires for the PT. Anything is better than the stock wires. You don't have to upgrade to the 8mm and above wires also because it's not needed.
A lot of us get our mods and parts from www.RaceandStreet.com they have good parts, fast delivery and great customer service. But if you want to save on shipping, your local auto store can get you what you want.
Old 11 May 2008, 03:56 pm
Thank you again for your help....
First time here, I think I need a tune up shamuu Tech & Performance Forum 9 18 Apr 2008 06:30 pm
tune up question plugs etc. mikey Tech & Performance Forum 7 07 Feb 2006 08:49 am
Sudden loss of power(need tune up?) Ctown Tech & Performance Forum 21 16 Jan 2006 08:41 am
Midlife TUNE UP help plz Ctown General PT Cruiser Discussions 9 29 May 2005 04:09 pm
Tune Up Alan Tech & Performance Forum 6 28 Aug 2004 04:27 am
