| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
This is a weird one, on the dash the gauge which shows your direction and outside temp, well the gauge won't go past 84 degree's.. it's about 103 outside today, way above the 84 degrees..
so i'm thinking the temp sender must be defective. but i'm alittle curious if this might affect the engine, as i imagine the ecu ? might be thinking it is only 84 outside so it might run alittle rich or lean. it goes below 84 degree's when it is cooler outside just seems to stop reading above 84 and stays at 84 ?? it's going into the dealer soon anyway, but i'm wondering if anyelse has come accross this.. maybe it's somthing else more common.. also the ac terrable at idle, but i'm thinking there not related.. 2006 turbo pt...tx mike |
The reading has nothing to do with the engine or ECU?. I take it you have a newer cruiser as the older models only read the outside temperature on the overhead console. It gets it's reading from a sensor that's located in back of the grill and in front of the radiator.
The computer checks the incoming air for the correct air/fuel mixture by means of a sensor connected to the ribbed air intake located between the air filter and the throttle body. The service manual indicates that the outside air sensor is not adjustable and must be replaced when faulty. There are two diagnostic tests (sensor and circuit) that your dealer can perform to determine if the sensor is working correctly. On your second concern about the a/c being terrible at idle ....make sure your fan is running when your at idle and the A/C is on. If not, you might be headed for an overheated condition.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() Visit My Home Page www.CREWZIN.com Last edited by CREWZIN : 17 May 2008 at 07:42 pm. |
| Anyone use a wireless temp sensor? | crazie.eddie | Tech & Performance Forum | 13 | 15 Nov 2004 11:22 pm |
| autometer water temp gauge | dfunkdj | Turbo Performance | 6 | 23 Jul 2004 05:11 pm |
| Air Intake Temp using stock components | Dalite | Turbo Performance | 16 | 28 May 2003 05:35 pm |
| Install of Water Temp Gauge | jramosGT | Turbo Performance | 6 | 18 Apr 2003 03:35 am |
| Ins5tall of Water Temp Gauge | jramosGT | Tech & Performance Forum | 1 | 01 Feb 2003 07:42 pm |
