Whats the difference between key trouble codes vs odometer ones?
Old 18 May 2008, 08:56 am
sknight88's Avatar
Default Whats the difference between key trouble codes vs odometer ones?
I read somewhere to hold in the odometer reset switch while turning they key foward for self diagnosis. I did that , it counts up, flashes the VIN, then did FL0007 EE 15 BL 01 and then the gauges all go full foward, kinda neat seeing 140mph!
Then I came here, and see that a key on 3 times gives the codes, which I did and got "done" so assumably no issues.
But, whats the difference? What is the first one for? Thanks, great forum, Shawn
Old 18 May 2008, 03:05 pm
Default Re: Whats the difference between key trouble codes vs odometer ones?
The first one with the "holding the reset button down" is just a test of all the guages and some codes not needed by the consumer. The other test is what we owners need to try and diagnose any problems. You have none (done).
2000 PT. 100,000 miles, Original Owner
Old 18 May 2008, 07:34 pm
sknight88's Avatar
Thanks Crewzin!
Old 01 Jun 2008, 05:06 pm
Do these work on all of the years? I've got a 2002 PT with the analog speedometer and dash (aside from the odometer).
Have a great week:-)
Patrick.
Old 01 Jun 2008, 05:41 pm
Patrick.
I don't believe they changed the procedure for the codes until the last couple of years, maybe 06 and 07 PTs.
Old 01 Jun 2008, 08:21 pm
Thanks CREWZIN. That worked perfectly. It would be interesting to know what the codes meant though (just because I'm an information freak).
Patrick.
Old 01 Jun 2008, 08:50 pm
Look right above your posting in this Tech and Performance part of the forum and your see a "sticky" (which means it will stay there forever) entitled "error codes". That's the whole list .
...or just click on this... Chrysler PT Cruiser computer codes
Old 09 Jun 2008, 08:38 am
Hi, I just bought a used 07 Base PT with 34K miles. I am VERY pleased with car. After one week of driving however, I had my MIL light come on(picture of engine). I tried the on-off 3 times routine mentioned above and I get 6 dashes where the odometer reading was, and after 5-10 seconds, the word "done" appears. Why would it not show a code? I also put my Innova 3100 code reader on and it gives a P1273 code which in the Sticky list says Accelerator Pedal Position Sensor 1. I'm still under (barely) my 3/36 warranty so I plan to go to a dealer today. But for future reference, as my warranty will be over in 2000 miles, I want to learn all the DIY tricks I can. Can anyone explain what I'm seeing?
Thanks, Mike
Old 09 Jun 2008, 09:16 am
Hi Mike,
Welcome to the forum. As I stated above I think they changed the procedure for accessing the codes in the 06-07 models years so hopefully someone will come along and explain how you retrieve the codes. The "done" on the older models does mean there's no codes stored in the computer but you say you got the P1273 with the code reader ...I don't understand that either.
Old 12 Jun 2008, 03:03 pm
Update on my MIL problem. Apparently the key on 3 times routine works. The reason I got a "done" with no codes was the code was "stored" but no longer "active". My Innova code reader was way off. The stored code was for a small leak in the evaporative system (like loose gas cap). Service dept cleared the code and put a new gas cap on and checked several other places that could cause this. No charge as I have 1500 miles left on warranty. I plan to flash update my code reader and see if it can read 07 codes then. Thanks for the input Crewzin.
Mike
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 9 28 Aug 2009 08:02 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Check Problem Codes Yourself! turbomangt General PT Cruiser Discussions 13 23 Feb 2006 06:27 am
Odometer & Trip Odometer tpscruiser Tech & Performance Forum 30 11 Dec 2004 06:45 pm
  Debt Consolidation | Game Card | Debt Consolidation | Wordpress Theme | Debt Consolidation
