K/n Air filter
Old 20 May 2008, 08:23 am
Question K/n Air filter
Hi everyone!!!!
I would like to know if this drop in filter allows more dirt to enter the engine? Will it shorten the life span of the engine
Thanks in advance
Old 20 May 2008, 09:08 am
Default Re: K/n Air filter
Wow, I take it you haven't done any research. K&N has been around a long time and if it's properly cleaned and oiled will not do any harm to the engine.
They (K&N) say that their filter straightens out the air flow letting a higher volume of air in while still filtering out any harmful particles.
Just using the drop-in K&N, you won't feel any difference unless you also take out the white dounuts from the filter boxes and maybe increasing the size of the inlet pipe which draws air from the fenderwell.
For most of us, the increased air flow took out the hesitation-from-start that the PT has using a stock air filtering system.
Old 20 May 2008, 11:54 am
soonercruiser's Avatar
Red face Re: K/n Air filter
Please check out some of the previous (historical) posts on the subject.
Frank, aka SOONERCRUISER,
Old 20 May 2008, 05:58 pm
Smile Re: K/N Air filter
Thanks Cruzin!!! I'm a neewbie and don't know much about PT's I'm used to those imports...
Old 31 May 2008, 04:07 pm
It won't increase MPG, so if you put one in, do it as a first step in improving performance.
Cabin air filter AlmondTurbo General PT Cruiser Discussions 36 07 Sep 2011 07:58 am
airbox foam breather filter, DIY replacement ptandme General PT Cruiser Discussions 2 14 Oct 2008 11:34 pm
Oil & Filter Change. one_fast_pt General Turbo Discussions 13 17 Jan 2004 02:32 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
