PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
what's up with these air silencers?
Old 26 Jul 2003, 12:11 am
secretspy secretspy is offline
Send a message via AIM to secretspy
Default what's up with these air silencers?
I've seen all this talk (typing, rather) about how if you remove your air silencers you will gain noticeable power, and it will sound better. Well, I've removed both the upper and lower air silencers, and installed a drop-in K&N filter, and there IS a different sound to it (which I like), but I must say I don't feel any power difference.....I am starting to wonder if these aren't really air SILENCERS, but more like devices to make the air less turbulent. Smoother flow would be better, yes?
Old 26 Jul 2003, 03:24 pm
Cal Cruzer Cal Cruzer is offline
I don't kniow if you mean on the turbo or not but if this is your reference no matter how "smooth" the airflow is, it is going to be very turbulent once it goes through the turbo. The "seat of the pants" dyno tells me throttle response if quicker but I think someone actually put one on a dyno and came back with more power. Was it Ian-PT-GT?
Old 26 Jul 2003, 03:50 pm
Gear_Head Gear_Head is offline
The silencers are designed specifically to absorb (trap) noise. The one in the intake tube just in front of the turbocharger looks like a glasspack muffler without the twists or packing. Besides restricting the flow they do anything but promote smooth air flow. It traps the sound, and a byproduct of this sound deadening is restricted air flow. I have the AMX1397 3" turbo up intake system which provides air intake with little to no restriction (only the filter provides any restriction at all). The air intake is much louder then w/the stock system, and also much more free flowing. I can understand DC using the silencers because the performance sound of the wooshing air and the turbo spooling up is not appealing to everyone, BUT I LOVE IT!!
[:X]
Alan
Old 26 Jul 2003, 05:31 pm
mine's not a turbo. But thanks for the info guys.
Old 27 Jul 2003, 08:07 pm
redvelvetswirl redvelvetswirl is offline
Send a message via AIM to redvelvetswirl
secret spy
Where can i get some more info on these silencers? I dont have the Turbo PT either, and im always interested in more sound.
Old 27 Jul 2003, 09:39 pm
Redvelvet,
I just found information by searching the forums. Other places you might look are:
PTCruizer.com
PTCruiserworld.com
PTforums.com
PT-tuning.com
It's pretty simple if you just want to remove them.....take the cover off your air-box. Look up inside and you'll see a white plastic tube. That's the upper one. It should slide out with minimal effort. You'll probably want to take out your airbox completely for the lower one. It's (to my understanding anyway, and it's what I removed) a black 90-degree bent plastic tube. Get a screwdriver and kinda pry under the tabs, this one will take some effort.
vB code is On
Silencers KingKole02 Tech & Performance Forum 3 13 May 2007 12:41 pm
Silencers? Paintball3r Tech & Performance Forum 3 13 Jul 2004 08:57 pm
Removing Silencers BL CRUZR Turbo Performance 12 28 Dec 2003 02:24 pm
Ok I give where are these silencers? thinguy Turbo Performance 3 28 Jul 2003 12:15 am
air box silencers onyx pt General Turbo Discussions 5 08 Jul 2003 04:52 pm
  RBS credit card | Cheap Flights | Golf Training Aid | Credit Card | Cheap Loan
