Fog lights won't turn off...
Old 28 May 2008, 03:01 pm
Default Fog lights won't turn off...
I have a 2002 PT Cruiser Limited Edition. I got in my car on Sunday before I even put the key in I noticed my fog light were on. It was in the off position so I turned them on and back off again and they will not turn off. The only way to turn them off is if I turn on my left turn signal. I called a dealer and they said it was the multi-function switch and quoted me $250 to fix. So my first questions is are they right about the switch? If I don't get it fixed could it cause more problems? And lastly could I just pull the fuse on my fog lights and not use them? I really don't have a need for them at all.
Thanks in advance!
Old 28 May 2008, 03:04 pm
Teekypt's Avatar
Send a message via Skype™ to Teekypt
Default Re: Fog lights won't turn off...
WOW!!!! This happened to me last week.
Yes, it's the multi-function light switch (hi/low beam, signal lights, and fogs). Yes, $250.00 sounds about right. my dealership quoted me $230.00, but I got it for $100.00, cuz of my service contract.
2003, GT, "ShuggaPlum", xenon bumper kit and Accra-Form Running Boards, custom tan/black neoprene seat covers (front & back).
Houston, TX
http://www.math.uh.edu/~tai/Today/Clean3.jpg
Old 28 May 2008, 05:53 pm
Yes, you can pull the fuse. I have a 2001 and the fuse is the Number #8 15A of the interior fuses next to your left knee. Problem is, that I don't know what else that fuse covers.
Old 28 May 2008, 07:31 pm
mjb457's Avatar
ALSO TAKE OUT THE BULBS,,,,$250.oo for a switch is like Jese James,,,but I know they have to get paid,,, good luck
Old 22 Apr 2009, 04:52 pm
Cool Re: Fog lights won't turn off...
I went to open the door to my PT after work and discovered that I had a dead battery. After getting the car jump started, I noticed the fog lamp indicator was lit.
I got out and saw that the fog lights were on, even though the switch was off.
I took out the bulbs, which were hidden beneath the mud flaps, and the green dash indicator was flickering every time I used the turn signal when driving, and I needed to jiggle the blinker's arm to make sure that I didn't leave the dash light still on while parked in the off position. Since I found the switch at RockAuto.Com, for $60, I might get a break on its installation. The dealer claimed that the part is back-ordered. There may be thousands of us replacing the same type of defective part. That's called planned obsolescence.
Old 22 Apr 2009, 08:19 pm
That's a good price - but make sure the switch you ordered has fogs - it can also be ordered without fogs and is cheaper. I replaced it on my daughter's PT, and I think I got the switch for about $75. Easy to replace, just need torqx wrenches for the actual switch.
Old 26 Apr 2009, 03:27 pm
Crap; just happened to me. Very wierd, even when the car is off, the fogs lights stay on. Is this the same issue everyone else was having. A few jiggles and I can get the lights and fog light indicator off; but sometimes the closing of the door will turn them back on.
Old 26 Apr 2009, 03:36 pm
Yep, sounds like the multi-function switch has burned/melted a couple of the parts together in yours also. If it's an 01-05 cruiser, pull the #8 fuse and that will shut the fig lights off till you replace the switch.
Old 27 Apr 2009, 07:16 pm
You were right on the money; multi-function switch. Had it replaced and all seems OK. Someone had posted earlier in this thread that turning on the left directional works to turn the fogs off; this is a great temporary fix so the battery doesn't drain because the fogs stay on.
Old 28 Apr 2009, 08:42 am
eklipsis's Avatar
is the multi-function switch the same as turn signal switch? same happened to me, actually was smoking so i pulled the fuse(also effects the hi-beams). link to autozones site for the turn signal switch only 100 bucks..
AutoZone
-Anthony
01_Pt_Cruiser
Fog lights won't turn off DCruzer Tech & Performance Forum 17 16 Mar 2011 07:16 pm
Fog lights won't turn on coolvirus General PT Cruiser Discussions 31 23 Jan 2010 04:08 pm
2006 Touring Edition - Lower lights never turn off EmeraldICE General PT Cruiser Discussions 7 12 Apr 2008 08:59 pm
LIghts, Lights, Lights King_Rob Classifieds: For Sale/Trade 4 20 May 2005 09:14 pm
Red Rear Turn lights Crash Exterior Accessories Forum 7 11 Oct 2001 04:28 am
