Starter Setup
Old 28 May 2008, 08:00 pm
PTmodrod's Avatar
Default Starter Setup
Maybe two weeks ago now, I set up a starter button in my car. The button is drawing from switched power and as such, still requires the key to be in the "ignition" position to work. I have a safety switch set up on the button so that no passengers get bored and attempt to start my already running car. What I need to know is how to bypass the need for the key to be in the "ignition" position. Will running a constant 12v feed (through a switch) and splicing it into the "ignition" wire of the key do the trick? DJmart seemed to know his stuff, so if you're reading this post, lemme know! (I do realize the whole stealability aspect of this setup and have secret plans on how to get around that, but that is for later)
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Old 28 May 2008, 09:33 pm
Default Re: Starter Setup
these cars have a chip in the key that has to be in very close range (1"-2")of the original position of the ignition switch. there are ways around this like the setup they use for a remote start kit, but this might have more "staelability" issues.....hope this helps some
TNJCRUISER
'06 inferno red, SRT8 magnum sound system, '07 17" wheels, eibach lowering springs, billet antenna, mopar nose cover, and custom bumper due to some girl on a cell phone
Old 29 May 2008, 06:04 am
PTmodrod's Avatar
Ah, you have an 06. That is when they changed body styles and added a lot of features (the new key being one of them.) Mine is just a plain old key, But thank you for your input
Pictures of my PT
New to the forum, and need a little help... vigeh Tech & Performance Forum 8 21 Apr 2008 06:02 am
Remote Starter for 03 GT Indynick General Turbo Discussions 6 22 Dec 2004 03:44 am
strut tower bar and stock setup question legion Tech & Performance Forum 3 27 May 2004 08:09 am
Aftermarket Air Inlet Setup tomcruz Turbo Performance 8 14 Apr 2004 04:45 pm
remote starter question jleforte Tech & Performance Forum 12 17 Jan 2004 11:38 am
