Swaybar link torque specs
Old 29 May 2008, 12:02 pm
Default Swaybar link torque specs
As I've stated in Front end link bushing replacement? AND Sway bars worth it?
I have a problem with my swaybar linkage breaking. This is the 4th time (passenger side 1 and drivers side 3). I have zero confidence in the dealership that has done the repairs. Couple that with the last time was a fight to get them to back their work I'm going to do this myself and hope for better results.
I have a '06 base model PT with the stock front swaybar. My 2 questions are:
1) Does anybody else have this problem?
2) Can a mechanic tell me what the torque specs are for the linkage?
I called Napa and the parts should only cost about $35-37 for the repair kit and bushings but I have to measure the swaybar size, he said it'll either be a 24mm or 26mm.
Thanks.
Old 25 Jan 2012, 02:18 pm
Default Re: Swaybar link torque specs
I have a 2001 PT with the same problem. Twice now. I too will do the work this time hoping for better results. What are the torque specs.?
Old 25 Jan 2012, 04:07 pm
In the repair manual there's nothing for "swaybar" but they do have the Torque for the "Stabilizer Bar".
Clamp Bolts = 21 Ft-lbs, 28 Nm
Link Nuts = 21 Ft-lbs, 28 Nm
torque specs? youngcruiser Tech & Performance Forum 8 21 Mar 2006 03:49 pm
Torque Specs irelandmoss Tech & Performance Forum 2 18 Jan 2006 09:07 am
bolt torque specs?? GTCruiser2003 General Turbo Discussions 1 30 Mar 2004 04:33 pm
WGA mounting bolts torque specs??? rice_killing_GT General Turbo Discussions 2 07 Mar 2004 06:44 pm
Strut bolts torque spec's? silky Wheels, Tires, Suspension 4 21 Jan 2004 11:17 pm
