I am the proud owner of a 2003 PT Cruiser GT Turbo. I love the car but my timing is off and needs to be adjusted. The car is not currently running thanks in part to some bad gas. All things being what they are I was hoping that someone could please explain to me how to perform a static timing check/ adjustment. I need help ASAP as this is my only ride so if you want to contact me on AIM, my screen name is: Bond and 4 Ever.
Thank you and I look forward to your replies |
Welcome to the forum. I'm pretty sure the timing isn't adjustable by you or your mechanic. Everything is controlled by the computer and sensors. There's the ECM (Engine Control Module), ECU (Engine Control Unit), PCM (Power Control Module) all doing sensor checks to keep things running. Only thing left to do by hand is gap the plugs.
Is there an aftermarket device, that allows changing ...the timing on the fly ??? A display with real time, data would be cool, but not a deal breaker if not so equiped... FYI, I am following the thread sarted by NotaDodge, which discusses a Hydrogen fuel cell, on a PT... My reason for asking about the timing, is this... After using adjustable MAP controls, with small output Hydrogen generators, the next step is to poduce larger fuel cells which may call for adjustments in timing... Hydrogen burns so fast that 100% hydrogen fueled engines, need ignition timg AFTER TDC !!! Where as gasoline, engines fiire before TDC... thanks, Ab Last edited by Abendicum; 25 Nov 2008 at 04:27 am. Reason: Clarifying the reason for the timing question... |
Timing is pcm controlled so I doubt if the timing is off. The only way to adj timing is with an aftermarket engine management system (around $1k) or a handheld tuner (around $400) like the Diablosport Predator which can hold up to five tunes.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
| Timing Belt Replacement | MarkB | Tech & Performance Forum | 38 | 30 Apr 2010 07:38 am |
| Timing belt kills air conditioning | customer20 | General Turbo Discussions | 9 | 19 Jul 2009 08:19 pm |
| 02 2.4L timing belt problem | ronwins3 | Tech & Performance Forum | 18 | 15 Dec 2008 08:57 pm |
| Platinum Plugs - Must change timing?? | bnorth | Tech & Performance Forum | 8 | 21 Jul 2007 10:15 pm |
| Another timing belt question thread :) ??? | Ctown | General PT Cruiser Discussions | 4 | 24 May 2005 08:50 am |
