Car dying!
Old 19 Jun 2008, 01:30 am
Default Car dying!
So twice now in the past few weeks, my car has died on me when i come to a red light. It starts right back up, but it worries me. Multiple times is drops to about 300 rpm when i approach a red light. Any ideas what the problem is? I have an 03 basic 5 spd. Thanks guys!
'03 Pt, headrest monitors, dvd, painted interior (kind of), modified air box, K&N drop in filter
Old 19 Jun 2008, 05:21 am
Default Re: Car dying!
Does the computer throw a code where the engine light comes on?
Stalling could be caused by many things but there's been a lot of problems with the IAC (Idle Air Controller) located attached to and in back of the throttle body. It might be malfunctioning or dirty. It controls the butterfly inside the TB and lets the engine speed come down slowly to an idle when you come to a stop. If it's not working properly, the butterfly shuts and the engine dies. It would start right up after that.
Old 19 Jun 2008, 06:42 am
What Crewzin said. Also, ignition wires often start to act up at idle - how old are the wires? Put new plugs in at the same time you do wires.
Old 19 Jun 2008, 11:28 am
I'm not sure how old the plugs and wires are. The cars an 03, I got it in March. Thanks for the help, I guess I'll try those and see if it helps. It just scares me that it's going to not start back up.
Old 19 Jun 2008, 08:12 pm
PTmodrod's Avatar
It sounds to me like the Idle Air Controller. I have to agree with Crewzin. My friends Jeep (or as it is now christened the "chEEP") had the same problem! We had to keep it revving in neutral at every light then click it into drive when it went green. Not good for the car, but it got us home... Chirping the tires at every light got annoying after the third time and I felt bad for he people around us. It should keep starting up fine, so no no worries there... unless I am wrong! DUN DUN DUUUUUUUNNNNN!
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Old 19 Jun 2008, 08:53 pm
wow. that was scary dont do that dun dun duuuuuuun thing anymore. bad
Old 19 Jun 2008, 10:09 pm
PTmodrod's Avatar
Awww fine. spoiling all my fun... lol
Pictures of my PT
Symptom of dying thermostat? tony_perreault Tech & Performance Forum 6 14 May 2008 06:13 am
Battery Dying or discharged? LoboMXGT General Turbo Discussions 2 11 Mar 2006 09:33 pm
The car feel like crap... a shaft may be Dying?? Ian-PT-GT Turbo Wheels/Suspension/Handling 11 28 Mar 2004 12:29 pm
dying out ptgt General PT Cruiser Discussions 40 21 Nov 2003 05:47 pm
Dying the suede door panels and seat panels Jerry Interior Accessories Forum 0 04 Jun 2002 04:35 pm
