question about brake noises
Old 24 Jun 2008, 06:19 pm
Default question about brake noises
03 GT
about 10,ooo miles ago I installed Pepboys Ceramic Brake Pads and I love em' but since that time I have a chirp chirp noise from one front wheel as it turns but stops as soon as you apply any brake pedal it stops and starts again when the brake pedal is released. Then, as the car starts to slow I hear a single clack noise from both front until the next time the brakes are applied.
The rotors were turned, the slide pins cleaned and relubed, Permatex brake squeal applied to all front pad backing plates and and all parts were cleaned of dust build up. The car stops clean and straight with no apparent problems. Anyone have any ideas?
thanks
Old 24 Jun 2008, 08:17 pm
JoeHundredAire's Avatar
Default Re: question about brake noises
Mine did the same thing. It ended up being a bad wheel bearing. Plus side...I got new brakes & rotors on the front now. Downside...I paid for them & the bearing. I would check to make sure the bearings good too.
Old 25 Jun 2008, 09:33 am
I had the same kind of noise on my 2006. Come to find out it was a little metal clip that was bent. Got it replaced at the dealer, it wasn't inexpensive, but was covered under warranty.
Old 25 Jun 2008, 01:44 pm
THS_Cruiser03's Avatar
Hooligan/Guys:
On my '03 I've had a problem (for a few weeks now) where when I am backing out of a driveway/parking spot and I turn the front wheels I ususally get a VERY LOUD squeaking noise. It won't do it if the wheels are straight though. Somtimes on one particular on ramp I use (broadly curved to the left) the sound will occasionally happen (even though the brakes are not being applied)but the squeak sounds as if whatever is causing it is making the squeak "cycle" at a faster rate.
Does this sound like the problem you were having or is this something different. And when I say LOUD in parking lots, I mean it turns heads from 50 ft away. The sound is definitely coming from the drivers side front wheel.
I also have the rear brakes "I've been sitting for two days and no one drove me" squeaking that goes away after two or three stops. I'm guessing that one is just rust removal. I was told this is common on PT's but not an issue.
With my particular problem there is NO degredation in brake performacne.
Thoughts?
Tom
Base '03, Light Almond Pearl Metallic - Modified 2.4 na w/ported head, 10.4:1 compression ratio & Crane #10 camshafts - 4 speed - Energy Poly bushings - Napa ceramic pads & Ultra premium rotors - Rotora Stainless brake lines - Extreme Acc. Xenon HID 8k low & 6k high
Dark taupe & Ivory Interior, Factory CD w/Sirius Stratus 4, Power Acoustik 840w 4ch, Boss 200w 2ch w 10" bandpass sub, 2 sets Phoniex Gold Matched comp. speakers
Rolling stock: 16" SE A7w 225/50/16 Kuhmo Ecsta AST - One of the nicest Light Almond PT's you'll find
Old 25 Jun 2008, 03:31 pm
Whatever the sound is, get it checked out by a reliable mech. Sqealing rubbing sounds don't improve on their own. And typically will lead to more costly repairs if left un-repaired.
I ended up having to replace a hub to rather than just the bearing because I didn't deal with mine ASAP.
If it's brakes & you don't fix it, you'll end up kicking yourself when you have to spend unnecesary cash on a new rotor too.
Old 25 Jun 2008, 04:21 pm
Hooligan, by chance do you know what the clip is? If not could you look on the invoice they gave you and give me the part number and or description
thanks
Old 25 Jun 2008, 05:41 pm
5017 857AA 1 SHIM KIT, Brake. I did not get a invoice, but this came from a 2002 Parts CD, be aware that the number may have changed. I tried to copy the part picture, but was unable to copy and paste.
Turbo Brake System Question R_I_PT Turbo Wheels/Suspension/Handling 5 03 Nov 2007 07:44 am
thanks folks, now the brake question gychang General PT Cruiser Discussions 3 13 Feb 2006 10:06 am
Brake pad replacement question nozzano22 Turbo Performance 17 09 Dec 2004 02:42 am
After market brake rotor question clevelandmike Wheels, Tires, Suspension 6 27 Jun 2004 10:30 pm
A brake question Alan Welch Wheels, Tires, Suspension 4 09 Feb 2004 06:38 pm
