REV LIMITER??
Old 28 Jun 2008, 01:42 am
Default REV LIMITER??
i have an 06 pt non turbo with a k&n cold air intake full cat back exhaust and new spark plugs and it sounds good but when its in park or neutral it only revs to 3500 rpm does anyone know how to remove it??
Old 28 Jun 2008, 02:37 am
Default Re: REV LIMITER??
It's a safety feature so you don't blow up your engine.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 28 Jun 2008, 06:55 am
You posted the same question in the General Section so I'll repeat what I said there and what MG just told you....
The limiter is controlled by the computer. You cannot override it. There's nothing you can buy to get around it. It's there to stop you from over-revving and hurting the engine.
Welcome to the forum.
Old 29 Jun 2008, 12:42 am
wat about the jet ecu chip? doesnt that change the entire stock computer?
Old 29 Jun 2008, 01:16 am
Send a message via MSN to Ironman
This is untrue, you can buy a several chips / ECU reprograms that will remove it...but why would you want to?
Old 29 Jun 2008, 08:00 am
Well, after doing some searching, I'll have to agree that the computer can be reprogrammed. There was a time (showing my age) that programming for Chrysler products was held under lock & key and aftermarket companies had to turn down requests for custom programming. Looks like all that's changed, maybe with the Chrysler buy-out.
Here's a company that can reprogram everything from the 2.4Litre to the 8.3Litre...
Welcome to B&G Performance Dodge/Jeep PCM(Computer)Flashes
Old 29 Jun 2008, 06:08 pm
You can possibly use the SCT tune to raise the rev limiter when going through the gears, but you'd be mistaken to remove the rev limiter in neutral and park.
Old 29 Jun 2008, 08:55 pm
what is the sct?? and theres a jet ecu chip for 280.00 i was thinking maybe that would work. the car sounds good when i'm driving and when i rev it a little i just want to be able to rev it all the way because i think it would sound better
rev limiter EddieJR666 PT Cruiser Convertible Forum 7 19 Jun 2009 08:29 pm
HELP WITH COURT & SPEED LIMITER! NICOLE-SMITH Tech & Performance Forum 21 29 Jun 2008 10:33 am
what is the speed limiter for a NA PT? Ctown General PT Cruiser Discussions 44 06 Nov 2006 02:22 am
does stage 1 PT Cruiser GT override rev limiter?? gtbright General Turbo Discussions 3 01 Nov 2004 05:31 pm
Stage I speed limiter MEXICANPT Stage Turbo Kits 1 20 Aug 2003 12:29 am
