Overheating PT
Old 28 Jun 2008, 08:32 am
Default Overheating PT
I have a 2001 base model PT with 81,000 miles. Never had any trouble at all 'til we got it paid off earlier this year. Brake lines collapsing, calipers freezing up, all kinds of great stuff.
Went running around yesterday and started home my Cruiser got to running hot. When we stopped, there was no water in the overflow. So I filled it up. Within a few miles, it got hot again, only this time, the water in the overflow was boiling and started running out on the ground. Checked the radiator and there was no coolant visible. So I filled it up and started home again only to have it running in the red while pulling into the driveway.
Just about to give it up. Any fixes?
Old 28 Jun 2008, 08:43 am
Default Re: Overheating PT
Welcome to the forum Deano.
The list is long for reasons of overheating. Bad thermostat, in-operative fan, bad water pump, cracked head gasket or loss of water from somewhere.
Lots of ways you can loose water and overheat and that's your first priority. Find out where the waters going. Any white smoke out the back? Any puddles on the ground? Pin holes in the upper or lower radiator hoses will leave large wet spots somewhere to be seen. What does the dip stick to your oil look like? Any foam or dis-colored liquid on the stick?
If there's no visible signs to you, you might want to take it somewhere to do a pressure check on the cooling system.
Old 28 Jun 2008, 03:46 pm
if you can hear like a gurggling sound in the overflow jug then i would suggest changing your thermostat first. I had a problem similar to that and it happen to be my thermostat.
Old 28 Jun 2008, 10:54 pm
dont forget radiator cap.....
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 29 Jun 2008, 08:03 am
water pump or thermostat
Old 29 Jun 2008, 01:13 pm
teahead's Avatar
Quickest thing to change is the cap.
If it works...then drain and re-fill with DISTILLED water and coolant; don't use tap water.
2006 GT Convertible 5-speed Black
Eibach springs/ST sway bars
19x8.5 ADR wheels
235/35, 245/35 General UHPs
20% tint/XenonEyes HIDs
PTeazer Roll Pan
Borla dual 2.5" cat back
Old 05 Jul 2008, 04:13 pm
No smoke. Nothing on the dipstick but oil. No puddles. No idea where the coolant is going.
How do you get the thermostat out? I've had everything loose (upper rad. hose, thermostat housing), but that's as far as I'll go without knowing for sure. The intake is in the way, so I'm guessing it has to come out, huh?
Old 05 Jul 2008, 04:51 pm
haven't done it myself, but the Haynes manual says the upper intake does have to be removed.
Old 06 Jul 2008, 06:50 pm
Can the intake be removed (or at least set aside) and be re-installed without new gaskets and all that sort of stuff?
Old 06 Jul 2008, 07:38 pm
Yes. Be careful how you take it apart and the four oblong gaskets that are between the two halves of the upper and lower manifold can be used again. They are rubber and fit into groves of the upper part of the manifold.
Overheating! Help ASAP KIMS CRUZER General PT Cruiser Discussions 35 12 Feb 2011 06:27 am
Overheating and stuff fredthedj Tech & Performance Forum 16 13 Jun 2008 10:29 pm
2001 PT Touring Edition - Overheating problem Rowarken Tech & Performance Forum 2 09 Sep 2007 09:26 am
Losing coolant and overheating when stopped dornstar General PT Cruiser Discussions 3 24 Aug 2007 06:16 pm
Overheating / A/C problem xyster Tech & Performance Forum 1 09 Aug 2005 07:40 am
