PT Cruiser Forum Car Videos
Custom Wheels
Weird Noise coming From Engine
  #11 (permalink)
Old 08 Jul 2008, 01:51 pm
Ironman Ironman is offline
Send a message via MSN to Ironman
Default Re: Weird Noise coming From Engine
Try doing the brakes yourself, its very simple, I've always done my own brakes and when I bought my cruiser I forgot to check the condition of them, turns out mine were very grooved as well. BTW do yourself a favor and get the more expensive rotors, they are made with a better quality steel and will last longer as well as being more resistant from "grooving" also, get yourself the ceramic brake pads, these are twice as expensive but will be well worth it as they will last for a long time and you will get hardly any brake dust. now, don't forget to bed the brake pads in the rotors (make several hard stops at moderate speed) also, if you have trouble getting the rotors off just use a dead blow and tap the backside.
  #12 (permalink)
Old 08 Jul 2008, 02:07 pm
CREWZIN CREWZIN is online now
Lots of little things to remember if you Do-It-Yourself. There's the anti-rattle clip that can be put on wrong so watch how it comes off.....
Not part of the braking system but make sure that each side had a grounding strap coming from the strut tower going over to the frame. It's been known to be missing in quite a few PT's and the results are bad wheel bearings. I know that sound "dumb" but something to do with static electricity not grounding and messing up the wheel bearings.
Back to the brakes, you'll need a medium to large "C" clamp to open the rotors once the old pads are off as the new pads will be a lot thicker and some grease to use on the pins that hold the caliper on.
2000 PT. 95K miles, Original Owner
vB code is On
New exhaust but weird fart noise when it shifts? ryeguy666 General Turbo Discussions 4 28 Aug 2007 08:42 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Engine "tapping" Noise. EJIII Tech & Performance Forum 3 03 Jan 2005 01:32 pm
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
weird noise NEED HELP!!!!!! skeeter1620 Turbo Performance 1 20 Dec 2003 04:35 pm
  MPAA | Personal Loans | Personal Loans | Debt Consolidation | Money
