PT Cruiser Forum Car Videos
Car Rims
Weird Noise coming From Engine
Old 06 Jul 2008, 03:55 pm
LVActor's Avatar
LVActor LVActor is offline
Default Weird Noise coming From Engine
So I'm driving my 05 Turbo convertible (that I got on May 1) and all of a sudden there's like a "thumping/sawing" noise" apparently coming from under the hood. If I accelerate, the noise gets faster. It stops when the car stops. No warning light on the dash.
I' m afraid to drive this car (for fear of causing any damage) to the dealer and am thinking I might have to have it towed.
Any idea what this could possibly be?
Old 06 Jul 2008, 04:09 pm
Mean Green Mean Green is offline
Default Re: Weird Noise coming From Engine
Stick shift? Sounds like a broken axle.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 06 Jul 2008, 04:12 pm
LVActor's Avatar
It's an automatic.
Old 06 Jul 2008, 04:21 pm
It's an automatic.
Check your motor mounts (torque struts). The rubber is very flimsy on those. If the bottom one is broken then the oil pan will get clubbed.
Old 06 Jul 2008, 05:06 pm
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Well the fact that the noise increases with speed and not revs means it is not engine or transmission related.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Pictures of my PT
http://www.banfielddesign.com
Old 06 Jul 2008, 10:19 pm
ptborder ptborder is offline
I'd check for something simple first, like a splash shield under the car dragging and rubbing on a tire. Had work done to it lately?
Old 07 Jul 2008, 09:24 pm
LVActor's Avatar
Angry Re: Weird Noise coming From Engine
Just got back from the dealer. Both front hub and bearings were worn out and the front control arm brusings were torn. Everything got replaced.
Kinda sucks that I just bought this car 2 months ago and only drove 300 miles since. You would have thought that a major dealer would have inspected everything before putting the car on sale.
Good thing I purchased the extended warranty. He quoted me $700 parts and $700 labor but it only cost me the $200 deductible.
Old 08 Jul 2008, 07:52 am
on an '05???
How many miles on it?
Old 08 Jul 2008, 09:23 am
LVActor's Avatar
It has 41,926 miles on it. On the brake inspection comment is says that the rotor is very grooved - fairly new pads. No idea what that means.
Old 08 Jul 2008, 10:33 am
CREWZIN CREWZIN is online now
It means that your rotors aren't giving you full stopping power and should be turned (sanded smooth) but I'd bet the pads aren't good either so you'd end up getting a full brake job, plus if the rotors are really VERY grooved, they wont' be able to be turned so ....new rotors and pads. A bunch more than your $200 deductible you just put out, and none of that is under warranty, sorry.
vB code is On
New exhaust but weird fart noise when it shifts? ryeguy666 General Turbo Discussions 4 28 Aug 2007 08:42 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Engine "tapping" Noise. EJIII Tech & Performance Forum 3 03 Jan 2005 01:32 pm
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
weird noise NEED HELP!!!!!! skeeter1620 Turbo Performance 1 20 Dec 2003 04:35 pm
  Oyunlar | Charity | File Host | Loan | Homeowner Loan
