i wanted to put a turbo on my pt. i was wondering if i could get the manifold, mounting bracket, oil line and the down pipe from a srt4. also what else im going to need. i know the turbo,new intake, bigger injectors,blow off valve, intercooler, larger fuel pump. and would i be able to used the intake from a srt4 also.
Ian |
you can check me against the Turbo section of the forum, but I think you're totally out of luck. Different engine.
The PT GT, turbo lite and Neon SRT-4 have the exact, same engine. The SRT-4 has different intercooler and plumbing, different intake manifold, different throttlebody, different 5 speed tranny and different pcm programming. The na 2.4 L engine does have weaker internals so you won't be able to boost past 8psi.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
so what parts will i have to get from a wrecked pt or srt4 to get my project moving?
Ian |
If you can, you should get a complete engine, or at least a short block, the oil pump, pistons, rods, & crank are all upgraded from the n/a engine, and the block has oil jets to squirt oil into the cylinders beneath the pistons, there is also an oil cooler at the filter, and the water pump is also different as the turbo is water cooled.
'05 GT Dream Cruiser Series 4. No.1109 http://www.alcamar.com/mods/ http://www.alcamar.com/dc4 http://www.alcamar.com/trailer/ |
Ian |
Either way, pull the engine from the wrecked one because you will be using most of the parts.
01, Inferno Red, PT LE, 5-speed Manual. EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads Custom Decals From Metro Car Design ![]() Pictures of my PT http://www.banfielddesign.com |
. i thank you a ton.
Ian |
| Turbo Replacement Question | PTCruzzn | General Turbo Discussions | 7 | 06 Jul 2009 07:14 pm |
| Blow Off Valve Conversion Kit | gonzomania | Tech & Performance Forum | 10 | 08 Sep 2004 09:08 am |
| Turbo leaking oil | 03baggedturbo | Turbo Performance | 5 | 09 Dec 2003 09:54 pm |
| 2003 PT Turbo Review by AUTOTEST FILE | Gary04GT | General Turbo Discussions | 2 | 12 Jul 2003 09:14 am |
| Chrysler to Offer New Cheaper GT Turbo | skylight | PT Cruiser News and Rumors | 19 | 12 Jun 2003 02:04 pm |
