Custom Wheels
Help with PT codes p0016 & p0339
Old 13 Jul 2008, 09:12 am
Default Help with PT codes p0016 & p0339
Ok so this is how the story goes, yesterday driving around and car stalls I get it going again then she starts to stutter. Im like oh great bad gas. Then I remember the The three key on trick, you know turn the key three times to with out turning car on to get the codes?
I do the Key thing and I get the codes p0016 and po339. So P0016 is " Crank and can out of sync" and p0339 is Crank Shaft position sensor intermittent. so my question is here. is have anyone of you had this problem yet? is it a easy fix or should a mechanic do this? and info would help..
I also found this post about poo16 '04 PT GT stalling, out of the blue...
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 07:58 pm
2003 Error codes Reed Tech & Performance Forum 4 15 Aug 2007 08:12 am
Check Problem Codes Yourself! turbomangt General PT Cruiser Discussions 13 23 Feb 2006 05:27 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
