Throttle Body
Old 13 Jul 2008, 11:23 pm
wiky86's Avatar
Default Throttle Body
I'm trying to research a performance throttle body for my 01 Cruiser, but so far all I've found are dead-ends. Anyone know something I don't? Thanks!
Old 13 Jul 2008, 11:51 pm
Default Re: Throttle Body
You could get it bored out. I've never seen an aftermarket tb offered for the na PT.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 14 Jul 2008, 12:23 am
wiky86's Avatar
Any ideas on where to get that done? I'm in Idaho, and sadly, the Cruiser is not all that big here. So parts and the like are hard to find.
Old 14 Jul 2008, 01:09 am
Got any performance shops around? They ought to know a good machine shop that specializes in machining car parts.
Old 20 Jul 2008, 06:27 pm
Send a message via MSN to Ironman
I wouldn't bother with it, I believe it is a 55 mm bore. there have been performance tests that indicate no improvement with a 65 mm bore.
Old 20 Jul 2008, 07:45 pm
Maybe not on the na PT. but a definite improvement on the turbo model. I'm pretty sure the stock tb is 52 mm. I've got a 55 mm tb from DCR (Darrell Cox Racing) on my '05 SRT-4 and there is definite throttle improvement. The 65 mm tb is overkill unless you go big turbo. 65 mm tb on a na PT would be a joke.
Old 21 Jul 2008, 05:54 pm
BUT, the originator of the question has an 01 PT so unless he added a Turbo (which he should have mentioned) the bored out TB won't do any good as Ironman pointed out.
I looked into a bored out TB for my Vette and like the PT, unless there are other improvements or upgrades (like the turbo) that can use the added inflow, adding the bored out TB doesn't do any good.
Old 21 Jul 2008, 06:22 pm
Ironman wasn't specific about turbo or non turbo. Just a blanket statement that really only applies to the non turbo. Personally, I wouldn't waste my money trying to get more out of the non turbo PT. You'll spend a lot of money for a limited increase in power.
Old 21 Jul 2008, 07:14 pm
Welcome home, CREWZIN!!!!
Old 21 Jul 2008, 07:20 pm
Thanks Ernie.
Crane Cams / throttle body WinDaddy Tech & Performance Forum 4 26 Sep 2007 04:09 pm
straw went flying into throttle body churdiales Tech & Performance Forum 14 01 Sep 2007 07:14 pm
AT Throttle Body in 5 Speed mvandale Turbo Performance 3 05 Dec 2006 12:03 am
POWERAID Throttle Body Spacer - Works?? matt87951 Tech & Performance Forum 17 23 Aug 2006 09:35 pm
Airaid Airmax and throttle body spacers Robster Tech & Performance Forum 22 22 Jul 2004 08:12 pm
