PT Cruiser Forum Car Videos
Custom Wheels
Rough Idle
Old 15 Jul 2008, 09:50 am
sobbad sobbad is offline
Default Rough Idle
Ok I am new here and have search some of the older post in regards to rough idle and cutting off after timing belt replacement. Just wondering what was the fix. Saw where one guy could unhook PCV and idle good but didnt post what he found to fix problem. Any suggestions?
Old 15 Jul 2008, 07:37 pm
bobs turbo pt bobs turbo pt is offline
Default Re: Rough Idle
welcome to the board !! are there new plugs in the car ?? if so what are they gapped at ?? just a thought
Old 16 Jul 2008, 06:28 am
No didnt replace plugs, but car ran fine up till belt replacement. I saw one post where a guy had the exact problem( right down to pulling pcv valve hose and would idle ok). I have tried to contact him to see what he found wrong with his since it was back in January but have not received a reply yet. Test drove car last night runs fine on the open road, no hesitation and power seemed fine just idle at stop is rough and cutting off. To me if the timing was off I would loose power and if the valves got bent should run rough all the time if at all. Any help is appreciated. I even removed IAC and tried cleaning (2001 with 110,000 miles)
Old 18 Jul 2008, 07:51 am
Ok here is a follow up. The rough idle and cutting off unless there was a vacuum leak was due to timing being off by 1-2 notches, mainly on the exhaust cam. I had timed the cams like the manual said notch to notch but they where not quite horizontal. So had to pull it back down and re-time. Did find a shortcut though, if you pull the right headlight assmebly out it gives you a little more hand room. GOOD luck
Old 18 Jul 2008, 08:44 am
Teekypt's Avatar
Teekypt Teekypt is offline
Send a message via Skype™ to Teekypt
Sobbad, when you removed the IAC, did you need to install with new o-rings???
2003, GT, "ShuggaPlum", xenon bumper kit and running boards, custom tan/black neoprene seat covers (front & back).
Houston, TX
Old 18 Jul 2008, 08:46 am
No I just put it back in. The problem was with the exhaust cam being out of time. The car is running good now
Old 18 Jul 2008, 08:57 am
Teekypt's Avatar
Cool. I asked because mine is idling a little rough...and I just replaced spark plugs and the wires, and just had a tune up.
I was thinking of cleaning the IAC, but the manual says that it has an o-ring that should be replaced. I didn't want to remove it, clean it, not replacing the o-ring and then have a leak....
Houston, TX
vB code is On
Help Rough Low Idle almost cuts off.. lockupman1 General PT Cruiser Discussions 6 15 Jul 2008 09:59 am
2004 Rough Idle A/C problems jiddypop Tech & Performance Forum 2 16 Apr 2008 09:58 pm
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 35 30 Dec 2007 10:41 am
Rough Idle BlueBlurCruiser General PT Cruiser Discussions 15 07 May 2004 09:50 am
New PT but rough idle?? Ed Tech & Performance Forum 3 19 Mar 2002 12:14 am
  Loan | News | Personal Loans | Ringtones | Debt Management
