PT Cruiser Forum Car Videos
Custom Wheels
Car Sometimes won't start (oil pressure light & Engine Light)
Old 16 Jul 2008, 06:54 pm
gerardio gerardio is offline
Default Car Sometimes won't start (oil pressure light & Engine Light)
Hello,
I have a 2002 PT Cruiser (touring edition). Within the past two weeks, I've had the car once per week not startup, and each time when the car would not start the oil pressure light came on, and the engine light as well.
On these two days, it was after I was driving around town and had the AC on bust while driving. It was after I stopped the car, and then when going back to start it up I encountered the problems. Each time the outside temp was around 30 + Degress Celisius if that info matters. The first time when it wouldn't start, I had the AC on bust when trying to start, and the second time the AC or fan was not on and it wouldn't start.
Each time I just waited a bit, left the AC off and after a while I was able to start the car up. The second time this happened, the car started up, the oil pressure light was off now, but the engine light stayed on. I brought the car to a local shop where they did a diagnostic on it, but by then the light had gone off,....
Just two weeks ago I had an oil change, and the coolant level is ok, and I had the water pump, head gasket, and timing belt just replaced as well,....
Any thoughts/advice would be great...
Thanks!
Old 17 Jul 2008, 06:13 am
CREWZIN CREWZIN is offline
Default Re: Car Sometimes won't start (oil pressure light & Engine Light)
Gerardio, welcome to the forum.
Even though the engine light went off, the computer generated a fault code and the shop should have been able to retrieve a code to help diagnose the problem. The oil light sounds OK, the engine just needs to get oil pressure up for a few seconds before the light goes off.
Have you had the battery changed since you had the car. Have that checked for a full charge and no dead cells. Always have the air-conditioning completely off when starting the car. The starter takes a lot of amps to turn over and having the AC on doesn't help.
2000 PT. 95K miles, Original Owner
Old 17 Jul 2008, 07:08 am
I just had a new battery installed in May of this year, but since installed, I didn't have it checked for any dead cells.
G.
Old 17 Jul 2008, 09:40 am
Don't bother with the battery, it's probably OK being that new. You had the head gasket replaced along with the timing belt so I take it you had a major problem before this. Was a tune-up done with the other work meaning were the plugs and wires replaced and plugs gaped at the new correct specs (.040in)?
Old 17 Jul 2008, 09:48 am
I didn't have a tune up done the past year, maybe this is what I should get done now.
Old 17 Jul 2008, 11:58 am
It doesn't have to be done every year, it just depends on the mileage that you put on from the last time you did have the plugs and wires changed.
Old 18 Jul 2008, 08:22 am
I can't recall if I had a tune up done in 2006 or not when I got the car, leaning more towards not tho. I have a tune up booked and asked them to check out the wires and plugs.
vB code is On
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Clearing check engine light Blade Tech & Performance Forum 10 27 Mar 2004 01:48 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 11 10 Jul 2003 04:55 pm
  Internet Advertising | Myspace Layouts | Equity Release | The Best Myspace Layouts | Web Advertising
