question about plastic manifold for turbo
Old 19 Jul 2008, 01:32 pm
Default question about plastic manifold for turbo
does any plastic manifold fit the turbo or is there one specificially designed just for the turbo?
Old 19 Jul 2008, 03:19 pm
Default Re: question about plastic manifold for turbo
In late 05 or 06 Chrylser replaced the cast iron upper manifold with the plastic one which was specifically designed for the Turbo. The plastic manifold from the non-turbo will not work on the turbo model. The new plastic manifold will fit on older models that had the cast iron manifold with just a little work to make it fit.
Old 13 Sep 2008, 07:08 pm
Talking Re: question about plastic manifold for turbo
Somewhere I read that the newer plastic intake mainfold was suppose to add 10hp to the engine. Can anyone confirm\deny this?
FYI, the older intakes were cast aluminum, not iron!!
neucruzr
Old 13 Sep 2008, 07:10 pm
The plastic manifold flows better. Is the extra 10 hp just the plastic manifold or was there a software change added, too? I don't know.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 13 Sep 2008, 07:39 pm
SRG SRG is offline
Originally Posted by CREWZIN View Post
In late 05 or 06 Chrylser replaced the cast iron upper manifold with the plastic one which was specifically designed for the Turbo. .
I think you mean cast aluminium,
srg
Old 13 Sep 2008, 08:22 pm
srg
Thanks. I was already corrected by Joseph.
Old 13 Sep 2008, 11:37 pm
SRG SRG is offline
Sorry, I guess I should read the whole thread before posting, but I have an excuse, I had just mowed the lawn and was/am real tired.....
srg
Old 25 Sep 2008, 08:00 pm
So.....we really don't know if (1) there was an increased airflow and (2) if yes to airflow, there was any hp gain?
SRG is cute, spelled aluminium the Cdn\British way, in the US its aluminum - pronunciation is also slightly different. FYI, I previously worked for a major aluminium company.
neucruzr
Old 25 Sep 2008, 08:21 pm
Don't know if you can believe them but here's a blurb from Haynes (Mopar) speed shop:
NEW for your 2003-04 and up PT Cruiser Turbo! This new Plastic PT Cruiser Intake has been redesigned from the factory aluminum intake to allow for a more even flow of air to each cylinder providing a better air/fuel ratio and increase of up to 8 HP.
Here's the link:
HaynesSpeed Shop :: Chrysler PT Cruiser :: Intakes :: Plastic PT Cruiser Intake Manifold Kit
PLASTIC GT MANIFOLD PROBLEMS? littleblueGT Turbo Performance 45 25 Nov 2011 12:10 pm
plastic manifold & stage 1 AlexJB Stage Turbo Kits 8 15 Aug 2008 03:13 pm
Plastic Intake Manifold cracked-boost leak! littleblueGT General Turbo Discussions 1 31 May 2007 03:25 pm
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
