| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
my 2002 Pt Cruiser AC compressor clutch will not engage. I just would liek to know which is the hot wire on the compressor that engages the clutch
There are 2 connectors on the compressor. At the top on the side nearest to belt you will find a black connector with a black wire and a Medium blue wire. Black is negative, blue hot. You need both! On the other end is the pressure switch. The compressor will cut off if there is low charge, this is most likely your problem.
mike@trickcruiser.com www.trickcruiser.com
You can confirm if it is indeed a low charge. Pull the Low Pressure Sensor connector of of the top of the accumulator. With the AC on jump the 2 terminals on the connector, If it kicks the clutch on, guess what? I recently had a similar problem.
PT powered PT with: Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection |
| Compressor Filter | Paw | General Turbo Discussions | 14 | 01 Mar 2005 11:42 pm |
| Compressor Surge | bigtommy83 | Stage Turbo Kits | 11 | 22 Dec 2004 08:23 pm |
| Turbo Compressor Stall - DANGER, DANGER, DANGER! | gsharrock | Turbo Performance | 19 | 14 Jun 2003 12:16 am |
| Air Conditioner Compressor | PT 7 | General PT Cruiser Discussions | 5 | 24 Jul 2002 06:40 pm |
| Hose head | BoyJusCruisin | Tech & Performance Forum | 2 | 30 May 2002 12:32 pm |
