Timing Belt
Old 31 Jul 2008, 11:12 am
Exclamation Timing Belt
What is the easiest way to replace the timing belt? Can it be done without professional assistance?
Old 31 Jul 2008, 02:25 pm
Default Re: Timing Belt
it can be done but its a pretty big job its also a good idea to do the water pump at them same time
Old 31 Jul 2008, 02:54 pm
When you talk about professional assistance, what are your qualifications? The professional assistance shouldn't need your help, if he/she is a professional.
There's been several members of this forum that have done it themselves, and a couple had to do it over again because things weren't lined up correctly.
A few have said it's the worst job they've ever tackled because of the placement of some of the bolts. A couple have said the engine has to be dropped a couple inches for clearance.
Do you have a service manual or even a Haynes book for some guidance?
It's recommended, as Bob said, to do the water pump at the same time. Also, if you have and 01 or 02 model year, Chrysler came out with a new tensioner in 03 that should be changed along with the serpentine belt and alternator belt.
Timing Belt Replacement MarkB Tech & Performance Forum 38 30 Apr 2010 07:38 am
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
Timing Belt Question bmore25 Tech & Performance Forum 2 28 May 2008 11:43 am
125K Miles.. getting timing belt changed this weekend - what else?? realized General PT Cruiser Discussions 4 16 May 2008 09:38 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
