PT Cruiser Forum Car Videos
Custom Wheels
Check engine light, skipping
Old 02 Aug 2008, 09:21 pm
ab1 ab1 is offline
Default Check engine light, skipping
Noticed car was not running to well, I came to red light and check engine light came on, started to have rough idle. When the light turned green and I gave it gas the check engine light went out. 2 weeks later Check engine light came on agian but the idle is ok, only it seems to be skipping when driving. I changed sparkplugs and wires, oil and cleaned the IAC motor (Idle Air Control). The check engine light went out after I did the following tune up, but it still seems to be skipping. Any ideas????
No codes No faults
Old 02 Aug 2008, 09:52 pm
CREWZIN CREWZIN is online now
Default Re: Check engine light, skipping
If the check engine light came on, there has to a fault code stored in the computer unless you took one of the battery cables off and cleared it.
When you checked for codes, did it read "done" or "no faults" since you say there were no codes.
2000 PT. 96K miles, Original Owner
Old 02 Aug 2008, 11:13 pm
ab1 ab1 is offline
it replyed no faults, and yes I did remove the negative cable when I removed the IAC motor, but it stayed on for about 5 mins after that. I did not know how to check for codes until after it turned off. bummer!
vB code is On
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 11 10 Jul 2003 04:55 pm
  Industrial Noise Control | Horoscopes | Mortgage Calculator | Loans | Debt Consolidation
