engine stalls or stutters while in idle or stopped with a/c on, but not with a/c off
Old 02 Aug 2008, 11:25 pm
Send a message via Yahoo to traumadude376
Default engine stalls or stutters while in idle or stopped with a/c on, but not with a/c off
engine stalls or stutters while in idle or stopped with a/c on, but not with a/c off. I found some info. that it may be related to the radiator fan motor relay , or the sensor near the thermostat???? any help would be nice. where do you find a repair manuel for the same veh.??
Old 03 Aug 2008, 03:56 pm
b0b88's Avatar
Default Re: engine stalls or stutters while in idle or stopped with a/c on, but not with a/c
my car does this as well, and it did not do it before my wife rear ended someone and the auto body shop repaired the A/C and teh Radiator plus all the front body that was damaged! they did a horrible job!@ anyway anyone that could answer this question would kick ass!
p.s. Is it just because the engine lacks power lol??
Old 03 Aug 2008, 04:03 pm
traumadude376, Welcome to the Forum!! To bad your first post had to do with a problem. As far as the Manual goes, do a search as there is a manual posted on the Forum> Good Luck!!
Old 03 Aug 2008, 04:15 pm
Ok... I'll diagnose this this one telepathically! Your radiator fan is not working properly. What happens is there is not enough airflow at idle when the a/c is on. That builds high head pressure in the system and causes the stutter. You will need a radiator fan and probably have the a/c system recharged because it probably has vented due to high pressure. Seen it numerous times!
Old 11 Aug 2008, 09:45 pm
ok, the fan comes on when the a/c is on and off when the a/c is off. a/c cools after several miles. compressor does not click on and off. when a/c on compressor clicks on. Wife said she sometime hears a pop when she turns a/c on. in the heat of the day (about 100 degrees) does not seem to cool at all.
Old 11 Aug 2008, 10:21 pm
I'm still leaning towards the fan. The low speed may function but the high speed may not be working. Also sounds like the a/c charge is low. If you can look under the car look at the a/c compressor. Look at the line underneath and see if it looks wet or oily. If so then the high pressure vent has vented. The fan can be a little harder to diagnose because it has 2 speeds and runs on low speed.
Old 12 Aug 2008, 12:15 am
agree with slarty. just had this problem, dealer replaced the fan assy. problem cured.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Engine idle sound and thud/pop when powering off KingKole02 Sound and Security Forum 10 04 Jul 2009 09:34 am
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 35 30 Dec 2007 10:41 am
HELP!!! ROUGH IDLE IN AM!!IDEAS?? mjb457 Tech & Performance Forum 15 23 Oct 2007 07:07 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
rough idle when stopped pvtsnowball Tech & Performance Forum 4 18 Jan 2006 04:12 pm
