long cranking
Old 05 Aug 2008, 06:41 am
Default long cranking
My cruiser seems like it has to crank a long time before it starts,is this normal?runs great,good power,just hard.warm or cold.150.000 miles Mobil 1 syn oil.no other mods
Old 05 Aug 2008, 07:09 am
Default Re: long cranking
Hi. The main cause of long cranking is bad ignition parts. It could be the plugs or wires or a weak coil since your at 150K. When was the last time they were all checked or replaced?
Old 05 Aug 2008, 07:26 am
The guy I got it from said that he had just replaced the plugs and wires,everything esle he has told me about it has checked out so I gues I believe him.Do the cruiser have a low pressure oil switch that won't let it start until oil pressure is up?2001 cruiser
Old 05 Aug 2008, 07:34 am
Not that I know of. I've never heard anyone talk about a low pressure switch. When you bought it did it have the long cranking time, or just start.
How about the timing belt. Recommended replacement is 100K along with the water pump and at 150K, the serpentine and alternator belt should also be replaced.
By the way, I checked the Haynes manual (not the greatest but does help) and there's a whole section on oil pressure and nothing about a switch that doesn't allow starting till the pressure is up.
2002 PT Intermittent Starting Problems, Very Long, Goes Back 3 Years BeBeCroozer Tech & Performance Forum 21 11 Jul 2011 09:30 am
Pt long trip advice neplan General PT Cruiser Discussions 8 17 Jun 2008 04:07 pm
miss under long and heavy throttle loads pppt03turbo General Turbo Discussions 19 26 Oct 2005 08:09 am
It's a long, long drive to Germany... Ed Lim Exterior Accessories Forum 0 05 Jun 2003 03:33 am
