Strange problem...
Old 09 Sep 2008, 05:32 pm
Default Strange problem...
All righty then,see if the wizards can figure this out. Last few days if I sit at a stoplight for more than a minute or so,when I let off the brakes to take off,about halfway across the intersection the brake light comes on with a "DING"! Not the abs light,but the brake light on the dash. The same one that comes on when you pull the hand brake. Doesnt happen all the time,and usually only about once or twice and then not again. 2001 Limited by the way. 4 wheel disc. 95000 miles.
Old 09 Sep 2008, 07:24 pm
Default Re: Strange problem...
Go out to your PT right now and check the brake fluid level in the reservoir. Odds are that your low in fluid. There's a sensor somewhere in the container and when you take off from a stop the fluid is pushed back against the side and the sensor thinks/knows your low in brake fluid. It then sends a signal to turn the brake light on to let you know.
Old 09 Sep 2008, 09:35 pm
I'll check it out. Thanks!
Old 10 Sep 2008, 05:52 am
just as crewzin said had the same problem with wifes car and it was low on brake fluid let us know what you find out
Old 10 Sep 2008, 07:06 am
Complely agree, but I see you have 95,000 miles... you replaced the brake disks? They could've worn enough that the brake pistons are out further, dropping the fluid level.
Old 10 Sep 2008, 03:16 pm
Well,yeah it does need brakes. Got 1 rotor thats got a little shimmy to it. The fluid was down to about the seam in the reservoir. I dont think that was too low,but I topped it off and we'll see. Thanks to everyone.
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
New to the Cruiser scene, Throttle Possition sensor problem ahdawg General Turbo Discussions 1 14 Aug 2007 12:02 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
need advice on strange electrical problem in Jeep comPuTer General PT Cruiser Discussions 1 07 Jul 2004 07:31 pm
