Strange cooling problem
  #11 (permalink)
Old 18 Sep 2008, 12:51 pm
Default Re: Strange cooling problem
When mine overheated and threw all the old red sticky anti-freeze all over my spotless engine because of a burnt out fan motor, I got it home ordered a new fan and filled it back with the same stuff you did; 50/50 Peak (love that Danica Patrick) and it's been fine for over two years now.
The ONLY fluid I know of that you should get from the dealer is the ATF+4 or 5 (synthetic) for the transaxle and I think you can find that after-market also.
  #12 (permalink)
Old 19 Sep 2008, 12:24 pm
if it is a blown head gasket you will either have oil in the coolant or coolant in the crankcase depending where the gasket is blown at. take your car to a radiatoe repaor shop and ask the pressure test your cooling system.....that will tell you for sure if it's blown or not or you may have a coolant leak elsewhere. if you still suspect air in the system I have always parked the car on a slight grade with the driver side down so bubbles will rise to the filler neck then I bleed it and get the air out
  #13 (permalink)
Old 01 Oct 2008, 01:58 pm
shaliberty's Avatar
Send a message via AIM to shaliberty
Hey Crewzin, that's good to hear, I kinda thought it shouldn't make a difference on the antifreeze. Last time we bled/refilled up again was one week ago, usually only lasts 3-4 days, before overheating, maybe the dang airleak sealed itself?Wouldn't that be nice? Having said that, it will probably overheat tonight when I have to go to Saratoga, about 30 mi. round trip. We shall see.....
  #14 (permalink)
Old 01 Oct 2008, 09:48 pm
shaliberty's Avatar
Anyone on here ever use this Thermagasket stuff that's being touted as an alternative for head gasket replacement? Saw ad on this forum, just wondering.
RxAuto Head Gasket Repair | Blown Head Gasket | Call 1-866-780-9042
Strange problem... ado63 Tech & Performance Forum 5 10 Sep 2008 03:16 pm
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
A/C .. and Engine cooling fan mystery delbassman Tech & Performance Forum 9 02 Apr 2007 01:14 am
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
need advice on strange electrical problem in Jeep comPuTer General PT Cruiser Discussions 1 07 Jul 2004 07:31 pm
