Problems!
Old 17 Sep 2008, 08:41 pm
PT17's Avatar
Default Problems!
Hi I just bought my used 2003 base model about a month and a half ago and after about a week the idle got reel rough and stalled at a stop light electrical and all went off. replaced the air filter, the idle switch valve and and put a auto lite spark plugs and wires in it and that sort of took care of the rough idling but it still stalls and it generally when it happens the break peddle gets hard to push down. i ran 2 bottles of "Chevron with Techron" carb cleaner and as far as i can tell it didn't do much of anything. My car also has a bit of hydrophobia and when it rains it stalls. but i heard Daimler Chrysler products have a history of that
just another
Old 17 Sep 2008, 08:44 pm
Default Re: Problems!
You said your replaced the "Idle Switch Valve" and I'm not sure what that is. Is it the same as the Idle Air Controller attached to and located behind the throttle body? It can be taken off and cleaned or replace pretty easily.
Old 17 Sep 2008, 08:54 pm
PT17's Avatar
yeah sorry kinda new to car part names, i bought it with 72,111 miles on it and all of the stuff i replaced was from 2003 when the car was new i found out
just another
Old 17 Sep 2008, 09:03 pm
Well, 2 things. First, when you stall the power assisted brakes no longer work and that's why the pedal gets hard so nothings wrong there. 2nd, one of the engine modules like the PCM (Power Control Module) or ECM (Engine Control Module) or ECU (Electronic Control Unit) the does controlling through sensors to adjust the idle so it won't stall when you come to a stop or turn the A/C on, so you might have a problem with one of them.
Old 17 Sep 2008, 09:08 pm
PT17's Avatar
Thanks ill have them looked at. but is the stalling during rainfall normal?
just another
Old 17 Sep 2008, 09:25 pm
No, that's not normal except for my old Triumph motorcycle filled with British Lucas electrics. The modern car isn't affected by rain, or at least shouldn't be.
Old 17 Sep 2008, 09:27 pm
PT17's Avatar
Ill get that looked at too thanks for the help
just another
Old 17 Sep 2008, 09:36 pm
Good Luck.
Old 17 Sep 2008, 09:50 pm
do you have the ac on when it stalls ??
Old 18 Sep 2008, 04:59 am
PT17's Avatar
nah my ac needs coolant and since the fall is right around the corner ill let it be for now.
just another
2002 PT Intermittent Starting Problems, Very Long, Goes Back 3 Years BeBeCroozer Tech & Performance Forum 21 11 Jul 2011 09:30 am
cruise control problems charlieborg General PT Cruiser Discussions 3 18 Jul 2008 12:24 pm
Constant 05 PT Problems - what's the deal? TEAMCATLOOK Tech & Performance Forum 4 12 Jun 2008 05:58 pm
2 problems with my PT gavaga General PT Cruiser Discussions 6 15 Nov 2007 09:25 am
'02 Cruiser with lots of problems :( slpknt2886 Tech & Performance Forum 4 07 Aug 2007 02:17 pm
