Error code p0106
Old 26 Sep 2008, 10:11 pm
PT17's Avatar
Default Error code p0106
How hard is this to fix and will it be expensive it reads twice one for total error and second a pending
just another
Old 26 Sep 2008, 11:00 pm
Default Re: Error code p0106
I just got a 5000$ furnace and it has a window that will display error codes than you look at the back of the door and it tells you what all the error codes mean
PT Cruiser Inferno Red GT Cruiser. 5Spd 215HO HP 17" Chrome wheels, Chrome gas cap, door spears, door handle cups, door buttons,door lock pins, vent covers,rear spoiler,rear painted mudflaps,, chrome/carbon fibre/like ebrake cover, wiper jet covers,bra, seat covers,Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover, chrome antenna bezel and chrome 12:" antenna,rear quarter window decals, winter car cover for winter storage, special made DREAM CREWZER dash plaque.upper windshield eyebrow tint , gts headlight protectors, carbon fibre taillight covers,car cover,K&N drop in filter, AMX intake pipe, shiny metal steering wheel spoke covers:Mopar door sills, rear chrome licence insert.street series badge,billett grill,engine start button, red brake calipers,painted engine manifold,chrome vent knobs,chrome/carbon fibre shift knob
Old 26 Sep 2008, 11:04 pm
PT17's Avatar
A Furnace? In my car? I Know what the code means the code reader i have tells me it. but is it an expensive, hard to do repair repair
just another
Old 27 Sep 2008, 12:10 am
Cathy06PT's Avatar
Send a message via AIM to Cathy06PT
LOL what exactly did that have to do w/ the topic of this post!?! Hahahaha
Old 27 Sep 2008, 05:11 am
P0106 Manifold Absolute Pressure (MAP) System Performance, that is what I got when I Googled it. Not sure what it means, hopefully someone with more info will chime in. Sorry.
Old 27 Sep 2008, 09:18 am
MANIFOLD ABSOLUTE PRESSURE (MAP) SENSOR TROUBLE CODES
These include P0105, P0106, P0107, P0108 & P0109, and can be set if the MAP sensor output remains too high or too low (out of range), or the MAP sensor readings do not correspond to the Throttle Position Sensor (TPS) readings.
MAP sensors monitor changes in intake vacuum, which is a way of determining engine load. When engine load goes up, intake vacuum drops. Vacuum is highest at idle and drops during acceleration and wide open throttle.
The computer uses the MAP sensor's input to vary ignition timing and the fuel mixture. So a MAP sensor problem may cause drivability problems such as surging, poor fuel economy and performance.
MAP sensors either generate a voltage or frequency signal as engine vacuum (load) changes. Vacuum leaks can cause problems with the sensor's reading, so check for leaks and the sensor's vacuum connection to the engine.
How to check: a MAP sensor's voltage or frequency output should change when engine vacuum (load) changes. If you don't see a change, the sensor is probably bad and should be replaced.
Old 12 Oct 2008, 08:19 am
PT17's Avatar
Smile Re: Error code p0106
I brought it to a mechanic it turned out to be :
1.Map Baro sensor
2.timing belt
3.and apparently the previous owner messed around with the idle adjust screw and broke
4.half my throttle body.
$1,748.62 in repairs
but its finally fixed
just another
Old 12 Oct 2008, 06:14 pm
OUCH! Glad your happy, that's all that counts.
